Failed emissions-gas tank pressure check
Old Apr 19, 2008 | 10:50 PM
88JDO's Avatar
88JDO
Default Failed emissions-gas tank pressure check
Took my 88 in today for the bi-annual test. Passed the sniffer tests but failed when they pressurized (?) the gas tank. They replaced the gas cap with theirs (had a small hose that went to a compressor or vacuum source-not sure which) and used a clamp to pinch one of the lines under the hood. It was one of the canister hoses but not sure which. I checked all the hoses and they look good under the hood. Anyone encounter this problem?
Old Apr 21, 2008 | 06:31 PM
rodj's Avatar
rodj
Check the rubber hoses that connect the steel lines in the rear wheel well ; often rotten
