Shift light installation
Old Apr 20, 2008 | 12:03 PM
jakers's Avatar
jakers
St. Jude Donor '06
Default Shift light installation
I want to install a shift light in my car. I am requesting tips and suggestions.. Thanks!
Old Apr 20, 2008 | 06:31 PM
LD85's Avatar
LD85
I bought the Harlan Shift Light, it is small and and I use Velcro to attach it to the bottom of my dash.
Pros: small, low cost and simple.
Cons, you have to change the SHIFT rpm using the combinations of numbers on the PC board
VIDEO CLIP
http://www.harlan-engineering.com/st...hiftLight.mpeg
Old Apr 20, 2008 | 10:35 PM
jakers's Avatar
jakers
St. Jude Donor '06
VIDEO CLIP
Thanks! The clip shows night driving... is it bright enough to see if mounted to the bottom of the dash for day light hours?
Anyone else with a neat mounting idea? Someone around here once mounted one in the center AC vent!
Old Apr 20, 2008 | 10:54 PM
GS345's Avatar
GS345
St. Jude Donor '11
I mounted mine in the vent right of the steering wheel, hides really well. At night if it seemed too bright, just close off the vent. The part of the vent you cut in thru is really just a dead part anyway.
jeff
Old Apr 20, 2008 | 11:48 PM
96GS#007's Avatar
96GS#007
At the tail end of the video, you can see my Harland shift light pop on. This is at a driving school and I was taking a friend for a ride...
http://video.google.com/videoplay?do...29187765573845
Old Apr 21, 2008 | 12:29 AM
STL94LT1's Avatar
STL94LT1
Here's the writeup I used for my install of the Harlan.
http://www.hashmarks.com/ShiftLight/
Old Apr 21, 2008 | 06:58 AM
LD85's Avatar
LD85
Its plenty bright in the day time, I use mine for Drag Racing, and you cant miss the light.
Old Apr 21, 2008 | 07:45 AM
GS345's Avatar
GS345
St. Jude Donor '11
Thats the one I used
Old Apr 21, 2008 | 07:50 AM
90steelblue's Avatar
90steelblue
.. anyone happen to know if it's the same wiring on a 90? (white= tach lead, pink=hot key on)?
nice write up!
Old Apr 21, 2008 | 10:50 AM
jakers's Avatar
jakers
St. Jude Donor '06
Perfect!!! Exactly what I was looking for!
Old Apr 21, 2008 | 05:27 PM
DVNCI's Avatar
DVNCI
Man STL you always beat me to the punch.
To Shift light installation
