ABS wires at front wheels
Old Apr 20, 2008 | 01:09 PM
HAD2HAV2's Avatar
HAD2HAV2
Default ABS wires at front wheels
The wire insulation is dry cracking and falling off on my ABS wires at both front wheels. Can they be replaced by myself, or cleaned and wrapped with electrical tape, or needs to go to the dealer where you need an expert ABS mechanic.
Old Apr 20, 2008 | 02:53 PM
racebum's Avatar
racebum
do you have a service abs light on in the car? if you do what needs to be done gets a lot deeper. if you don't and you keep the car dry taping them up will work in the short term. be careful with water if you go the tape route though.
Old Apr 20, 2008 | 05:58 PM
HAD2HAV2's Avatar
HAD2HAV2
No code. Just wany to avoided one.
Old Apr 20, 2008 | 11:12 PM
C4boy's Avatar
C4boy
If the rubber is cracking, I would wrap it with electrical tape. There are 2 insulated wires inside the rubber outer coating, the rubber is just protective.
Old Apr 21, 2008 | 06:10 PM
HAD2HAV2's Avatar
HAD2HAV2
A little alcohol to clean then wrap with tape. I will have to look at the rear wire later.
To ABS wires at front wheels
