Runs Rough when WARM... Ideas?
I'm looking for some advice on what to try to solve my issue.
I have a 1990, all stock, with ONLY 21,000 miles. Over the last
few months, the car seems to run fun for the first 20min. Then
it starts to run rough...you can feel it most when at idle and in DRIVE,
but you can still tell it is running rough when moving as well.
This weekend, it got to 85 here in Baltimore, and after about 35min,
the car almost just quit while I was going 70mph. I was low on
gas (reserve with only 1 bar on the display), so I was able to
limp it to a gas station. I got gas, the problem was still there. No
power, could barely get it above 25mph. I let it sit for 2-3hrs, it
got me home, but still ran rough. Any ideas on steps to fix this?
Like I said, it is 18yrs old with the original wires/plugs/cap/rotor/etc.
Should I attack there first? What about fuel? New filter? Should
I mess with the idle air bypass stuff?. Being that it is worse when
it heats up, I'm thinking it isn't fuel related.
Any thoughts and ideas would be great. Thanks!
90 White Lightninghttp:
"1" "2" handshaking code...nothing after the "1" "2" code (even after 3 times flashing the "1" "2" code. Should I try to read the codes just after the car is running poorly?...I was assuming it stored them, etc.
First thing that I would do is to change out the fuel filter. Low miles are nice, but it does not mean you don't need to change the filters. And tuning the car up would also be a great idea. Remember, your car is still 18 years old. Have you ever changed to transmission fluid, or the brake fluid? rear differential? You still need to do this stuff.
Let us know it you need any help.
Randy
Time kills the type of injectors on your car, not miles. The coils are bathed in gas, and the insulators break down in all the emissions additives in today's gas causing them to short out and not fire correctly.
It's a good idea to change out those fluids every couple of years, cars are made to be driven, and sitting does not always agree with them.
Randy
BTW, if you used Seafoam in the gas, the injectors are now toast, I have first hand experance on that.
So...is it true.....If I used Seafoam in the gas tank for 1 tankfull, my injectors are history?
7.3, 15.5, 16.4, 11.3, 5.1, 2.5, 16.7, and 7.5
I'm guessing that all but about three of them (the 16.4, 16.7, and 15.5) are history???
I'm assuming just go ahead and replace all eight of them, correct?
How hard a job is this?.....It may be more than I want to tackle right now. I may have the mechanic down the street do it.....
If you have any other questions, just let us know.
I did it to my car, not that hard. If you send me your email, I'll send the writeup to you.
Randy
