91 rotor size
Old Apr 20, 2008 | 11:06 PM
littleredcorvette88's Avatar
littleredcorvette88
Default 91 rotor size
anyone know what size the front rotors on a 91 are thanks
Old Apr 20, 2008 | 11:39 PM
StealthLT4's Avatar
StealthLT4
If it has the standard brakes, 12". However, if it has the HD brakes, 13". If you have a ruler, that's the easiest method...but you can check the build codes. I forget the exact code, but there was a thread here recently on the topic.
Old Apr 21, 2008 | 01:40 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
J55
Old Apr 21, 2008 | 03:59 AM
janarvae's Avatar
janarvae
Originally Posted by RandyJ75
J55
Yes, and I believe JL9 is the normal 12 inch brakes. Check the RPO codes on the bottom of your armrest.
Old Apr 21, 2008 | 02:38 PM
littleredcorvette88
ok thanks guys
To 91 rotor size
