93 maf sensor
Old Apr 21, 2008 | 01:34 PM
vett40's Avatar
vett40
Default 93 maf sensor
total confussion does the 93 have one or not . first i tought it was in the air intake found out it was a air temp sensor. then some one told me it was under the asr . it has a vacuum line going to it an some wires. it also has a pipe that comes from the exhaust header pipe connected to it . or is that called the map.[ manifold air pressure.] please help clear this up . thank you for any help
p.s. does it need to be hook up or can you take it off
Old Apr 21, 2008 | 03:02 PM
Lichen's Avatar
Lichen
No maf in 1993. Speed density.
Old Apr 21, 2008 | 03:12 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
93's have a MAP. I know just got 2 codes on it this weekend.
To 93 maf sensor
