'90 Vette "pinging" when hot
Old Apr 23, 2008 | 11:08 AM
halfmoontrail's Avatar
halfmoontrail
Default '90 Vette "pinging" when hot
I'm a C3 guy, posting for a friend. PM or reply to this thread, thanks.
My friend has a '90, bone stock except for no catalytic converters. Low miles, excellent maintenance, premium gas (93 octane).
He mentioned that whenever the temp gauge shows above 220, typically when idling at a stop light or during a parade, if he accelerates there is a lot of "pinging". Not a problem any other times, and I gather that the car isn't overheating, my understanding is that the newer vettes typically operate above 220.
Is this a common problem; and/or is there a simple fix...adjusting/replacing a sensor or switch, changing cooling components, computer settings?
Thanks in advance,
Steve
Old Apr 23, 2008 | 11:15 AM
conv90's Avatar
conv90
You should NOT hear ping. Even it it start detonate, the knok sensor should send this information to the ecm . The ecm remove timing .
The ecm is able to remove up to 20 deg of timing!
Probably the KS is inoperative.
Old Apr 23, 2008 | 11:53 AM
CFI-EFI's Avatar
CFI-EFI
But check the sensor and the ESC before you start replacing parts. Are there any codes set? If so, follow the trouble shooting chart in his FSM.
RACE ON!!!
Old Apr 23, 2008 | 03:44 PM
halfmoontrail
Default Thank you!
Thanks, Conv90 and CFI-EFI.
Steve
Old Jun 24, 2008 | 03:03 PM
halfmoontrail
Default Knock sensor fixed it!
My friend changed his knock sensor and it resolved the problem. Thanks to all who posted in response to this query.
Steve
Old Jun 26, 2008 | 08:40 PM
guido7834's Avatar
guido7834
Now, my 87 pings with 89 octane and not 92. Does this seem to indicate a bad knock sensor also?
Old Jun 26, 2008 | 09:35 PM
mcfack's Avatar
mcfack
Funny, my car does the same thing and a guy at work today mentioned the same sensor.
Hmmmmm? Maybe I need to look into this!
Old Jun 26, 2008 | 09:38 PM
Lichen's Avatar
Lichen
Try running some 91 octane.
To '90 Vette "pinging" when hot
