90 Corvette Rear window Question
Old Apr 23, 2008 | 03:07 PM
tachout's Avatar
tachout
Default 90 Corvette Rear window Question
I have found a replacement window for my Corvette, to replace the ugly fiberglass thing that is there now. I would like to know what kind of tool is used to remove the black round holdowns that connect the glass to the rest of the assembly that makes up the third brakelight, and hinge and all. Also where can I get one, as I want to swap mine over myself
Old Apr 23, 2008 | 11:55 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Back when I had my '85, one of those "screws" came loose and I just tighted it up w/ a screw driver.
Old Apr 24, 2008 | 12:13 AM
tcr75's Avatar
tcr75
I may be wrong but I believe that it takes a large torx bit
Old Apr 24, 2008 | 09:09 AM
tachout's Avatar
tachout
I know it is not a torx but it is something similar to a spanner wrench. Tonight I will try to take some pictures of it, and post on here so maybe someone can tell me how to take these off and make the swap.
Old May 3, 2008 | 03:01 PM
tachout's Avatar
tachout
Well I got the black things off, and the torx back there takes off the third brake light itself. Now all I need to do is find out how to take that adhesive off the glass. That sucker is really bonded to the flat piece
Old May 3, 2008 | 06:57 PM
WW7's Avatar
WW7
I used a pair of needle nose pliers, open them up, put a point in each hole and unscrew it. Easy...WW
Old May 3, 2008 | 10:52 PM
vetteoz's Avatar
vetteoz
I don't know that it is supposed to come off.My replacement glass came with the mounting plate already bonded on.
Old May 3, 2008 | 10:56 PM
Road Agent's Avatar
Road Agent
To 90 Corvette Rear window Question
