Auto rear seal
Old Apr 23, 2008 | 03:31 PM
ukpete's Avatar
ukpete
Default Auto rear seal
Can anyone confirm that the correct part number for an auto transmission rear yoke seal for a 1994 Covette is # 24232325 , the part supplied to me looks a different design to what is currently on my gearbox as it has an extended rubber shroud/boot facing towards the drive shaft...
Old Apr 23, 2008 | 03:45 PM
toptechx6's Avatar
toptechx6
Originally Posted by ukpete
Can anyone confirm that the correct part number for an auto gearbox rear seal for a 1994 Covette is # 24232325 , the part supplied to me looks a different design to what is currently on my gearbox as it has an extended rubber shroud/boot facing towards the prop shaft...
If you are talking about the driveshaft yoke seal, the number I come up with is 24201470.
Old Apr 23, 2008 | 03:48 PM
ukpete's Avatar
ukpete
thanks, will double check with my supplier tomorrow...
Old Apr 24, 2008 | 04:58 AM
ukpete's Avatar
ukpete
P/N 24232325 supercedes 24201470, as it has been modified to prevent leak problems....
Old Apr 24, 2008 | 11:58 AM
toptechx6's Avatar
toptechx6
Glad it turned out to be the correct part.
To Auto rear seal
