Hedman Elite Install?
Old Apr 24, 2008 | 06:58 AM
armybyrd's Avatar
armybyrd
Default Hedman Elite Install?
Just bought my Elites for my '88 C4. Whats the average time it takes to install these? WHere exactly should I have the bung for the o2 sensor put in?
Old Apr 24, 2008 | 11:32 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
It took me about 7 hrs, but I was also doing other things also. Really only one place to put the o2 and that is in the collector. You will probably have to run heated o2's. Take off the valve covers, it helped me get the the back bolts on 7 & 8.
Old Apr 24, 2008 | 12:23 PM
armybyrd's Avatar
armybyrd
Does it make a difference if you put the o2 sensor after the header?
Can I still use my factory starter?
Old Apr 24, 2008 | 12:27 PM
armybyrd's Avatar
armybyrd
For removal of the factory manifolds whats preferred to get the bolt farthest back on the passenger side? The heat shield gets in the way of getting the socket on all the way.
Old Apr 24, 2008 | 01:13 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
As I stated, take off the valve covers and use a box end wrench. If you put the o2 after the collector, you will have to run heated sensors.
Old Apr 24, 2008 | 02:17 PM
armybyrd's Avatar
armybyrd
Thanks for the tip but as I stated the problem was more with the exhaust manifold shield being too close to the bolt head. Idk if taking the valve covers off will help though I guess I'll have to give it a whirl
Old Apr 24, 2008 | 02:25 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
I just banged mine a little bit, maybe your year is closer than mine.
To Hedman Elite Install?
