Knock Sensor...WTF
Old Dec 14, 2001 | 08:59 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Default Knock Sensor...WTF
The fans started coming on with a cold engine and then an SES light... had it scanned and coded a knock sensor ( so I was told)... had two new sensors put in this afternoon, left the shop and 10 miles later the fans come on (192 degrees) and the SES light :mad .. any clues out there ?? all help is appreciated...
Old Dec 14, 2001 | 10:38 PM
HighHopes85's Avatar
HighHopes85
Default Re: Knock Sensor...WTF (golfboy1)
Sounds like you ended up hitting some kind of limp home mode routine since the fans were comming on with the engine cold.
Go out, turn the key ON and see if the fans come on. If they do, go back to the shop and set em straight. Unless you specifically told them to replace the knock sensors instead of 'fix my problem', they should make ammends with you. -Matt-
Old Dec 15, 2001 | 12:14 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Default Re: Knock Sensor...WTF (HighHopes85)
Thanks for the thought 85... just turned it on... no fans... my corvette guy coded it as knock sensors and replaced both.. something is making the fans come on below 220 degrees :confused: ..guess I'll have to show up at his shop Monday and see what the SES codes this time...
Old Dec 15, 2001 | 12:21 AM
HighHopes85
Good deal. Fans on with Key ON and Engine OFF is no fun...-M-
Old Dec 15, 2001 | 12:23 PM
KYVette90's Avatar
KYVette90
Coolant Temp Sensor
Old Dec 16, 2001 | 12:48 AM
TravisD's Avatar
TravisD
My 96 set codes for the knock sensors that ended up (likely) being a bad computer. After it set about 6 codes at once they swapped it out - and 3 computers later it was fixed. Yes, they got 2 bad ones in a row. Gotta love "remanufacturing".
Old Dec 16, 2001 | 08:47 AM
MTVette's Avatar
MTVette
Default Re: Knock Sensor...WTF (TravisD)
My '92 auto was throwing a code 43 last summer. Swapped out the knock sensors without success. Swapped the ecm, and Bingo! No more SES lights.
Rebuilt ecm's are for sale on the forum for under $100, and replacement takes about 15 minutes. Go for it.
To Knock Sensor...WTF
