Throttle Response slow
Old Apr 25, 2008 | 10:32 AM
Demonic85's Avatar
Demonic85
Default Throttle Response slow
I've heard everyone talk about how much better the throttle response is on the L98 over past carbed and crossfire models. I think mine is slower than older cars. Is there a way to increase throttle response or determine if something needs fixed?
Old Apr 25, 2008 | 11:36 AM
Muffin's Avatar
Muffin
Adjust your TPS. Should be .54 volts.
Old Apr 25, 2008 | 11:38 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Step on the pedal faster.
Old Apr 25, 2008 | 11:51 AM
hexane's Avatar
hexane
Your spark advance may be off. Check to see if the base timing is set at 6 degrees. Or for even more throttle response, set it to 8 or 10. You might have to start using premium gas if it pings.
Old Apr 25, 2008 | 11:54 AM
tequilaboy's Avatar
tequilaboy
Check your timing first.
You can also experiment with spark advance to try and produce the most vacuum at idle. This should help.
Otherwise, you need to get into the tune's AE and perhaps the MAF filtering to speed up response.
I'd guess its going a little lean as you open the throttle.
Old Apr 25, 2008 | 12:15 PM
ernie22golf's Avatar
ernie22golf
Default Mine too
I just had cap, coil, plugs, plug wires and one injector & fuel pump & filter changed - rather costly hoping to get throttle response up but it's still same - car previously idled rough when warm and injector was root cause but plugs, cap, coil & wires were also partly problem. Mine runs great at full throttle but in part throttle starts just not much response. I
Old Apr 25, 2008 | 08:37 PM
John A. Marker's Avatar
John A. Marker
First check you timing. My 85 likes 10 degrees better than 6. (trial and more trial and a few errors).
Next check the TPS. The TPS should be set to .54 volts when the key is turned on (car not running). Then have someone step on the gas peddle all the way to the floor..... now check reading....it should be 4.49 at WOT. If you have adjusted only to .54 you may be loosing the full WOT response. The TPS can be moved so you get both readings, just takes a little time.
I have my TPS adjusted to .60+, it seems to respond a little sooner. Past members have indicated that their cars like about .63.
And check your fuel pressure. When was the last time you changed the fuel filter? I have heard some information that the AC Delco filter has a larger diameter opening than other after market filters and flow better. I have not checked this aspect of the filter out yet. I change my filter about every 10,000. I have the FP set at 40 psi at idle and the FP hose off the regulator and plugged.
Old Apr 25, 2008 | 11:53 PM
Demonic85's Avatar
Demonic85
My timing is at 6* and my TPS is at .54 volts and steadily increases up to like 4-4.5 volts at WOT. I havent tried adjusting it higher though.
My fuel is pretty much all new (injectors, pump, filter) and I had a Holley AFPR on it but it had no affect on the throttle response or anything for matter except making the car run rich, lol.
Is there a way to adjust the throttle cable or anything like that?
Old Apr 26, 2008 | 01:06 AM
John A. Marker
Set you timing up to 9-10 and the TPS up to .6 and see how you like it.
They are easy things to do and return to original settings.
The throttle cable is a one time adjustment (there is no linkage adjustment). Here are the one time adjustments:
1. On the side of the throttle body you will find the TV cable. There is an adjustment locking tab that you press in.
2. While pressing the locking tab move the slider towards the back of the motor.
3. Release the locking tab and operate the throttle to full WOT and the slider will automatically adjust itself.
4. Drive the car.
-John
Old May 2, 2008 | 12:35 PM
19vette89's Avatar
19vette89
how do you adjust the tps?
Old May 2, 2008 | 01:28 PM
Swift_Striker's Avatar
Swift_Striker
throw in an LS9, if that doesn't solve your problem I would suggest jet turbines.
Old May 2, 2008 | 05:14 PM
bobmic93's Avatar
bobmic93
You could try a top end clean out with Sea Foam unless you have the multec type injectors.
Old May 2, 2008 | 05:37 PM
Happydad's Avatar
Happydad
This helped me alot...
Old May 2, 2008 | 06:20 PM
guido7834's Avatar
guido7834
Excuse my lack of knowledge, but what is TPS?
Old May 2, 2008 | 06:28 PM
Happydad's Avatar
Happydad
Throttle Positioning Sensor...Didn't think I knew that did Ya'll
Old May 2, 2008 | 06:29 PM
black_89_vette's Avatar
black_89_vette
Throttle Position Sensor
Old May 2, 2008 | 07:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My method of adjustment is on my site. If you get it adjusted a tad too high at idle the ECM will toss a code and you can back off a bit.
Once the TPS is optimized try advancing base timing into the 8-10deg range or until ping is detected.
Also, clean the TB & bore with TB cleaner.
Old May 2, 2008 | 07:12 PM
Master__Shake_'s Avatar
Master__Shake_
4. Drive the car.
-John
Wow.. I just did that. I thought it was just something that would kick it up a few RPMs but damn.. I actually hit 6k RPMs for once. Like a night and day difference. So much power I was missing.. and the response is better too. Just goes to show what a little tinkering will do.
Old May 2, 2008 | 10:04 PM
hexane's Avatar
hexane
To Throttle Response slow
