Injectors-Buyer Beware
Old Apr 25, 2008 | 08:29 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by _twisted_
I was referring to the plugs
In your report I didnt see any pressure listed.
I have 30's at 43.5, but the tune reflects 26._ @40
Sorry CFI had me off....
They were tested at 3 bar, 43.5..
Old Apr 25, 2008 | 08:33 PM
jsup's Avatar
jsup
Originally Posted by CFI-EFI
In one post it's a SPEC. "but are you recommending going against manufacturer spec and throwing in hotter plugs to compensate for faulty injectors?". But in THIS thread it's a "STARTING POINT". Make up your mind. I'm getting dizzy following you, going in circles.
Are you a retired English teacher?
Anyway, how's this. Manufacturer's starting point spec...is that better
You just don't get it.
RACE ON!!!
I understand where you're going, but it's irrelevent until I fix what I know I can get right. THEN I can start looking at the plugs.
Old Apr 25, 2008 | 08:57 PM
dgoodhue's Avatar
dgoodhue
Originally Posted by jsup
I hope this proves useful to someone. I had to have Alvin re tune my chip, twice (I bet he wants to kill me).....I had the chip tuned to 37lbs, the injectors were putting out 40.
To make it easy you could always turn your base fuel pressure down to compensate and make the 40# injectors look like 37# If you base FP is 43.5, to make it look like 37# it would need to turn down about psi. (37/40)^2 * 43.5
Ultimately different injectors typically wil notl flow in linear fashion. For instance your 40# injector may not flow 67% more fuel 1.3 ms pulse (idle) like a factory 24# at 1.3ms. At 100% duty cycle it should flow 67% (assuming they are rated at the same fuel pressure)
Old Apr 25, 2008 | 09:09 PM
jsup's Avatar
jsup
True enough, but that has other implications.
I think I'm just more pissed that I purchased a 37, told it was really a 38.3, and really flowed 40.
It costs time, money, and aggravation.
Old Apr 25, 2008 | 09:10 PM
CFI-EFI's Avatar
CFI-EFI
No. Especially since you are treating it as a, cast in stone, spec. And if I DIDN'T pay attention to what you actually WROTE, I'd be in trouble for that. Say what you mean and mean what say. Don't try to make YOUR failure to communicate, MY fault.
You haven't a clue where I'm going or where I'm coming from. Truly, your don't have a clue.
RACE ON!!!
Old Apr 25, 2008 | 09:15 PM
jsup's Avatar
jsup
RACE ON!!!
It's YOU.....truly YOU don't have a clue....not YOUR.....big difference....
Anyway, I'll concede, I don't have a clue. How about you provide some clues and we'll play puzzle and I'll try to figure it out.
Old Apr 25, 2008 | 09:29 PM
mechguy79's Avatar
mechguy79
Well this will be locked soon. It's kind of hard to pick out the info with all the bashing. Why can't people just agree to disagree?
You two are both smart and I read a ton of your posts so please calm it down a little before you guys get banned or something.
Old Apr 25, 2008 | 10:09 PM
Kool88vette's Avatar
Kool88vette
Jsup:
I got burnt twice with bad injectors. The first time they were rebuilts. The second time it was new yellow top Accels.
Nothing will make me more irate than to spend time, money and effort only to have the car run like crap.
I'm on my third set of injectors now and all is well. I just hope that the injectors last.
I'm usually the one ranting and raving about being burnt by dealers that sell you bad or the wrong injectors. So I know what you're going through.
You'll get things squared away soon.
We really need to be careful and choose the right injector regardless of the price. I tried to save money and it cost me.
I want to drive my Vette not rip it apart.
Old Apr 26, 2008 | 10:06 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
I could be wrong but as mentioned you may have not let the car run long enough. The ECM/PCM will adjust the duty cycle based on the O2's over a short period of time. A tune just gets you in the ballpark so to speak. Once again I could be wrong but I believe it would have the ability to compensate easily for that 3lb difference. The only caveat here is when the injectors are so oversized that the duty cycle drops so low as to make the flow unreliable. I can't remember the exact # but the duty cycle at WOT should be under 90% and that is what is important. I would be much more upset if the injector under flowed leading to the engine going lean at WOT.
As mentioned the plugs may be out of spec causing (or helping) the carbon but just as you need to datalog after a tune it takes time for the PCM to tweak itself so the tuner can do his job.
Overall the pattern and flow rate are not as important as the duty cycle and that is what The tuner adjust for based on your setup as that determines the most efficient flow.
Old Apr 26, 2008 | 10:12 AM
jsup's Avatar
jsup
I completely agree with all that. Again, did I buy a 37, 38.3, or a 40 and how do I tune a car based on these injectors as a starting point when the constant is unknown?
Too many moving parts.
Could the plugs be too cold? Sure. Could the combination of cold plugs and a bad tune produce this result? Sure. However, when you start with a bullshlt rating these other variables are impossible to nail down.
It's like X+Y=4. What's the value of X? That's my point. Unless I can get a solid baseline from known specs, which I would expect from a manufacturer, how am I supposed to adjust the other variables effectively?
It's a function of time, money, and aggravation becuase specs ain't really specs and as the consumer I don't see why it's my responsibility to figure it out. I should get what I pay for.
Old Apr 26, 2008 | 12:00 PM
Redeasysport
I am still not sure what you expect. Injectors are not made in a lab and can and will vary some. Maybe 10% is a little extreme. Mabey the supplier needs to rethink what he tells his customers. Tuning a PCM is far from an exact science too. All in all I think you may be making too big a deal about it. As long as they all flow the same it will probably take the same amount of dataloging/dyno time to get it tuned. There are so many variable inside the engine itself. As I said I would want an injector that flows more than advertised than less any day of the week as long as it is not excessively so. The PCM can compensate for richness but the engine will blow/overheat/ run bad on lean.
Old Apr 26, 2008 | 12:51 PM
Carl Johansson's Avatar
Carl Johansson
You bought 40 lbers. you're right the manufacturer/vendor was "wrong". the photos of the plugs show it was running rich. to bad you did not have a set of 37's around - i suspect if you ran them with new plugs - they would look the same!
did the vendor return your money after you returned the injectors?
Carl Johansson
Old Apr 26, 2008 | 02:52 PM
  #33
jsup's Avatar
jsup
Carl Johansson
Nope. I have no more contact with that vendor. They have no phone number listed, it's an email only business.
I have another vendor who took back those 40lb injectors and traded me straight up for 25s. I am seriously considering going with 30s or 32s. I have a couple days to decide. I really believe 30s would be dead on ***** for my application.
Old Apr 26, 2008 | 02:55 PM
  #34
jsup's Avatar
jsup
When I got them flow tested they were 40lbs. They are stamped 40. They are 40s.
The vendor told me they were either 38.3 or 37. Which they are not.
I know what you are saying about none of this being an exact science, however, having parts that don't perform as advertised don't make it easier.
Old Apr 26, 2008 | 04:09 PM
  #35
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
My recommendation was 30's a month ago. Hopefully NEW 30's.
Old Apr 26, 2008 | 06:20 PM
  #36
BAM92's Avatar
BAM92
And if you had a supercharged/turbocharged car and bought underrated injectors as compared to your overrated ones, now that would get expensive. I too want to know exactly what I am buying.
Old Apr 26, 2008 | 07:50 PM
  #37
jsup's Avatar
jsup
I finally ordered a new set of 32s. I'm not jerking around any more. They are brand new and flow matched. they are 30lb bosh rated 32 at three bar.
I agree with you. That's where I need to be.
I got them from FICINJECTORS. Jon has been very good to me and I have no problem giving them my money. Hell, he called my house TODAY on a Saturday when he got my email. How many people do that?
  #38
jsup's Avatar
jsup
Right. That's my point.
Old Apr 26, 2008 | 09:44 PM
  #39
larryfs's Avatar
larryfs
[QUOTE=Kool88vette;1565189580]Jsup:
QUOTE]
may I ask....
what happened with the new accel;s?
The new accels are suppose to be OK.
