Help With Brakes!
What is a good combination?
Sorry for all the questions but I feel as though stopping is a big deal and is usually over looked.
Why do you think you have a brake problem?
First thing I would do is totally flush the brake fluid, don't forget the ABS (I think 84 had ABS). Use a good fluid.
Check the caliper boots and pistons move in and out without binding.
Buy some good pads and put them on.
I'll bet after that they will work a whole lot better for not a lot of money.
If you have to replace the rotors only use the drilled and slotted for BLING not for autocross or HPDE.
Is there any sign of fluid leakage around the calipers? Are the hoses original? This might be a good time to install new or reman calipers, replace the hoses (you can use stainless lines for a little better pedal feel) and add new pads. A good street pad like the Hawk HPS will help with braking performance and not kill the credit card. Another good street pad is the Raybestos Brute Stop. Expect some dust with either of these pads.
If you want bling, you can use drilled and/or slotted rotors. They are fine for the street but the stock wheels don't really make them visible. You can go with stock rotors and save money and still be able to take the car out for a track day.
Do a complete brake fluid flush using a good DOT3 or DOT4 fluid. Castrol LMA, Ford HD Motrosports fluid, and Valvoline are good DOT3 fluids. You can use a DOT4 if the car will see some track use, but DOT3 will be fine for most all street and autocross use.
with C4cruiser. He did a really good write-up some time ago at http://forums.corvetteforum.com/show...t=Blue+loctite. I'm not sure though if the procedures and torque specs apply to your year.
I have the Hawk HPS and NAPA rotors and they're great. Zero squeaks or squeals out of the Hawks and amazing bite. As for fluid, I know that for me the first two brake fluids are harder to find. Most autostores (Autozone, Advanced Auto Parts, etc) will have the Valvoline SynPower synthetic formula DOT 3 & DOT 4 brake fluid in stock. It should come in a gold bottle if they haven't repackaged it since I used it last time.
Order some authentic SpeedBleeders (unless you already have a power bleeder) from http://www.speedbleeder.com/ with the money you save from skipping the slotted and drilled. They make bleeding the brakes a much quicker, cleaner, and easier job.
Do you go to USF by any chance?
Good luck,
Jonathan
You can do it all for under $400.00. That's the way I am going.
Rich K
