Do you need shift Kit for 4L60e?
Old Apr 29, 2008 | 02:45 PM
JimiHendrix's Avatar
JimiHendrix
Default Do you need shift Kit for 4L60e?
I just rebuild my transmission, and despite Hypertech programing, all new seals and pistons, rebuilt pump, 1/2 turn on pressure solenoid, my shifts are solid, but not tire chirping. I attribute a little of that to the 2000 stall speed. The 1-2 shift feels slightly clunky. But then again, I havent bashed the pedal yet.
My car is a 1996 Lt-1, hot cam, magnaflows catback, 2000 stall, hypertech II power tuning (their standard program) everything else is stock.
It seems that because the transmission is electornically controlled< i dont need a shift kit.
Should I go install the transgo hd2 kit anyway to get that tire chirping type shift?
Old Apr 29, 2008 | 08:44 PM
JimiHendrix
A dumb question I suppose?
Old Apr 29, 2008 | 08:59 PM
aminnich's Avatar
aminnich
No such thing as a stupid question, just stupid answers.
A friend has a 46 chevy pick-up with an Lt1 (slightly modded) and a 4L60E with a shift kit in it. On street tires it burns the tires on every 1-2 and 2-3 upshift, even under moderate acceleration. He is taking the shift kit out as he is concerned about loosing it on wet roads. Best I can do, hope it helps.
Old Apr 29, 2008 | 09:37 PM
Ryan59's Avatar
Ryan59
Absolutely!!!!
Read here>http://www.transmissioncenter.net/4l60e.htm
Old Apr 29, 2008 | 11:33 PM
JimiHendrix
Thanks Ryan!
It seems that the shift kit will remove that light throttle bang shift I am experiencing....along with other slight drivability problems.
I just took the car out and stomped on it a few times. WOW!!!! It seems the shifts firm up considerably when I put my foot into it. I also noticed that when I get up to sayyyy 75mph and let my foot off the gas, the transmission stays in gear. It didn't do that before, it seemed that transmission free wheeled, then caught a gear......very uncomfortable. The 2-3 shift is very stout with no slippage all. . . no matter how much I stomp it. I raised the rev limiter to 6200. . . .and it bangs it right into third no problem. Rods next?
I also noticed that the torque converter lockup is far more pronounced, even though I didnt remove the little ball in the input shaft. I am pretty sure my old converter clutch was slipping.
I am extremely pleased. . . .except for that light throttle bang, and the temps got into the 220 range . Time for a cooler.
Old Apr 30, 2008 | 10:11 AM
hangonsnoopy's Avatar
hangonsnoopy
Default B&m
I installed the B&M **** Kit. Works great. The Trans Go has more things you have to install
To Do you need shift Kit for 4L60e?
