Removing clips from Injectors??
Old Apr 29, 2008 | 07:43 PM
Brett Richmond's Avatar
Brett Richmond
Default Removing clips from Injectors??
I think I have put up a question about every part of the process so far What is the trick to get these off without breaking one as I have already broke one of the clips and I am not in the mood to break any more. I have the fuel rail separated so now the clips are the last thing in my way before I finish the long put off project.
Old Apr 29, 2008 | 07:47 PM
Johns87's Avatar
Johns87
I just put the little tab on the edge of my workbench and 'roll' the injector out of it. You will break some if they are old and/or rusty (and they are ALL old, now).
I hope this helps, Take Care, -John
Old Apr 29, 2008 | 07:58 PM
Brett Richmond
Mine are still in the motor under the fuel rail right now.
Old Apr 29, 2008 | 07:59 PM
Stewball's Avatar
Stewball
Brett,
What I did on mine was you'll see a little tab on the left side front when they are locked in. Slide the tab to the right. If you can feel behind them or have the fuel rail off there will be a large tab on the back and now it will be on the left side. This means they are unlocked and you can pull them from the rail.
There seems to be some discussion on the forum about whether to use them again or not. I am no expert so I’ll leave that decision to you and the pros. I replaced mine from Summit Racing. They come in packs of 8 for under $12.00 a pack.
Stewball
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Screw the clips, you don't need them. They are a relic from the assembly line to ensure injectors didn't fall out while on the line, kept them in the rail.
Old Apr 29, 2008 | 08:00 PM
John A. Marker's Avatar
John A. Marker
Rotate the clip with a flat screw driver.
Old Apr 29, 2008 | 08:01 PM
Aardwolf's Avatar
Aardwolf
They just turn, take a look at the one you have off to see how it works.
Old Apr 29, 2008 | 08:03 PM
Kool88vette's Avatar
Kool88vette
Pull the fuel rails off with the injectors attached.
All you have to do is push the tab on the clip.
The clips will spin around and release the injector.
I got new clips from Summit Racing. They're cheap and easy to replace.
Old Apr 29, 2008 | 09:14 PM
BAM92's Avatar
BAM92
Only thing they are good for is pulling the rail with injectors to see when pressurized if one is leaking, other wise you don't need them.
Old Apr 29, 2008 | 09:26 PM
Road Agent's Avatar
Road Agent
Old Apr 29, 2008 | 10:34 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I grip the edge of the clip with plyers while rotating the injector away from it; once it's installed on a new injector I pinch the clip with plyers to "install" it.
To Removing clips from Injectors??
