I am starting to put my newly aquired 1990 L98 Vette back together after replacing my fuel injectors, unfortunetely the factory service manual I won on Ebay has yet to arrive.
If anyone knows could you please post the torque values for those 12 (I think) bolts for the intakes. Any help is VERY much appreciated!!
the good ole chiltons says 25-45 ft.lbs and also there is a specific sequence in which you are supposed to tighten. its in section 3-14 if you can get your hands on the book. hope this sends you down the right path!
TIGHTENING-from front to rear.left 2-1-3-4-5-6 right 8-7-9-10-11-12.The book says 25-45 ft pounds.I used the sealant that came with my gaskets last fall.I'm having to do it again this time I'm using the Right Stuff from Permatex.I hope its the last time I have to do it.
