Please Help, Won't Crank
Drove home from work. Parked car. Next morning car won't crank. Lights come on, battery is charged, no cranking at all.
Try to jump start, no luck.
Try to push start, no luck.
I take the key out, wait at least 3 mins, try again, no luck.
Arm, disarm PKE, no luck.
So I take the buick, and tow the vette to the shop.
Finally get around to going to the shop to start on the car. First things first, I test the batterty. Jumped the noid, starter works, car cranks. Starter is good. Battery is good. Next I check fuses, everything seems in order. Fuses are good.
Still no crank. So I check the clutch pedal relay, bypass the relay and still no crank. Relay is not the cause of my problem.
Car is getting fuel pressure, turning iginition on turns on fuel pump. Fuel is definately not the issue.
Is there a starter relay on a 96 LT4? If so, where is it exactly?
I really think it is a security problem. I don't have anything aftermarket. When the door is open the security light blinks. When I turn the ignition over the security light stays constent. Does this mean the VATS is screwing me?
VATS? Is a worn out key my problem? I don't know my code and don't have a spare.
How does the ecklers bypass work, and do you think it will help me in this situation?
Pros, can you please chime in on this one!
Don't permanently bypass VATS because 99% of thefts are done by bashing the column and jumping the ign. One further cause may be a defective start enable relay. The VATS circuit closes the start enable relay when the correct pellet resistance is measured and the relay supplies 12v from the ign sw crank contacts to the clutch safety switch and from the clutch sw to the starter solenoid. If you jump 12v to the clutch safety switch jumper, the starter should crank proving that you have a good connection through the firewall connector and down to the starter solenoid.
Where is the starter enable relay? 96 LT4 Manual Tranny obiviously.
Good luck.
If the Security light stays on, it indicates the resistance value of the key pellet doesn't match what the CCM is programmed for and will not allow the starter to engage.
CCM DTC code 51, 52 or 53 will set. The codes will clear when the proper key pellet resistance is read by the CCM.
When an improper resistance value is read, there will be a random delay around 3 minutes before you can try to start the car again.
Could be a worn or dirty key pellet, bad contacts in the igntion switch or ignition key cylinder wiring.
There are 15 possible key pellet values. You can use an ohm meter and compare it to the table listed in following url. If you don't have a meter go to Radio Shack and have them measure the key pellet.
http://www.cadillacforum.com/m_5779/mpage_1/key_/tm.htm
If you purchase a new key cylinder, make sure you get the one for a manual trans. You'll have to purchase a new Vats key with the proper key pellet resistance value and have it cut for the new key cylinder which will come with a blank key.
Thanks, I was hoping that was it. I will definately try this next. Any suggestion on where I can find out what key resitence I should get. Can I tell by my VIN? I have a feeling my old worn out key is the problem. Will the meter tell me the correct resistence on a worn out key?
I am glad we got it started and hopefully it shouldn't ever bother you again.
Turns out it was the lock cylinder itself that was bad (wasn't reading any resistance from the key at all)
It was great to hang out and shoot the breeze afterwards too. Hopefully we can get our cars running soon and go cruise around a bit (still waiting on 2 clutch cylinders and now a batter added to the list *sigh*)
I hope to be redoing the website soon and Eric was cool enough to let me get some pics of under his dash so I can help more of you out with visuals of what to do. I got some better pics of how to solder all the resistors and such too that I will be getting up online later as well.
Just remember... vatssucks (.com) LOL
How perfect is that URL name !!!! I just bookmarked it, waiting for '94 vatssucks information...
Beautiful....just beautiful !!
