How much timing ?
Old May 2, 2008 | 09:46 PM
BLWN BUX's Avatar
BLWN BUX
Default How much timing ?
Just curious,
How much total timing are you guys running.
I am:
30* at 12# with 50/50 (91)gasoline and 110
have run on just 91 but feal better with some 110
No issues
Old May 2, 2008 | 11:44 PM
tequilaboy's Avatar
tequilaboy
At the moment I'm at 23.91 degrees above 4800 rpm with 7 lbs. of boost on 93 octane.
My spark table dips down to 20 degress between 3600-4000 rpm since I seem to pick up knocks there and ramps back up to 24.
Old May 3, 2008 | 09:38 AM
CRV3TT3's Avatar
CRV3TT3
My car was tuned at 27* with 6*btm on 93, but i have bumped it up to 8*btm so 29* and running on a 50/50 of 93/100 both sold at a local sunoco. Havent had a chance to get it to the track or have it retuned since the new heads and intake were put on so not sure how much it gained from it.
Old May 4, 2008 | 12:03 PM
AKS Racing's Avatar
AKS Racing
I run 21° at 25+ psi, but at mild boost levels, the timing is still in the very high 20°s. A lot depends on the cam and head selection, but many tuners tend to be conservative on timing to ensure there are no knock problems.
Aaron
To How much timing ?
