Help on brakes!!
Old May 3, 2008 | 07:16 PM
jim_hewett's Avatar
jim_hewett
Default Help on brakes on 94 LT1!
Out of the blue excessive pedal pressure needed,w reduced braking capability w hissing noise each pedal application. Leaking vacuum booster maybe?
Getting technical here. For you "been there done that gents".
Studied FSM..appears just DS knee bolster(panel w carpeted facia) has to be pulled to expose two nuts mounting booster to firewall..right? Will this removal also expose rod to brake pedal attachment?
Old May 3, 2008 | 09:24 PM
Da Mail Man's Avatar
Da Mail Man
Originally Posted by jim_hewett
Out of the blue excessive pedal pressure needed,w reduced braking capability w hissing noise each pedal application. Leaking vacuum booster maybe? New rotors & pads 9K mi ago probably not a factor.
...your booster or check valve is "history"........
