Need Help Asap! Stuck On Road!
Old May 4, 2008 | 09:43 AM
jwalters's Avatar
jwalters
Default Need Help Asap! Stuck On Road!
I am in dire need of technical help. My clutch slave suddenly lost all its fluid. I am on the road under my vette and have it out and apart. I checked FAQ and found the alert on seals on backwards but no info as to proper orientation.
Which way is the lip supposed to face?? Right now as configured, by looking AT the pressure side of the piston the open end of the seal is at the non-pressure side. Is this correct??????
Old May 4, 2008 | 11:53 AM
SAY WHEN's Avatar
SAY WHEN
Default seal
the lip of the seal should go towards the body of the slave cylinder--ie lip towards the fluid--however the seal itself must have went bad if you lost clutch all at once and /or a leak at clutch master cylinder or pressure line between the the two components --even a small/slow leak would mean that once the fluid got low enough you would lose your clutch pedal--possibly just adding fluiud may have limped you home or to a repair shop depending on where you are---hope this helps
Old May 4, 2008 | 12:05 PM
Yellow2015's Avatar
Yellow2015
When mine went out, I filled the master, kept pumping the pedal until the car was driveable and drove it to the shop. I did have to "top it off" every so often when I felt the pedal get weak.
Old May 4, 2008 | 01:33 PM
CFI-EFI's Avatar
CFI-EFI
You don't need a clutch to get anywhere. Put the trans in first gear, hold the clutch pedal to the floor to close the interlock switch, and crank the engine over. As soon as it catches feather the throttle to get underway without bogging the engine. You can shift gears, up or diwn, by synchronizing the engine speed to the road speed with the throttle. At a stop sign or light, slip it into neutral and shut off the engine. Once stopped, put it in first gear. When the light turns green repeat the start up described. You won't hurt a thing and you'll save a tow bill. Then you can fix it in the comfort of your own home.
RACE ON!!!
Old May 4, 2008 | 02:20 PM
toptechx6's Avatar
toptechx6
RACE ON!!!
Have to laugh at this one sorry This might be great advice in Utah, but trust me when I say the traffic in Florida is a nightmare. I'm not saying you couldn't do this safely but if you can you are one hell of a driver and my hat is off to you .
I might have given this a shot when I lived out in the boondocks in Ohio but think it would be a suicide attempt here, I would pay the tow bill with a smile on my face before trying it in Florida.
Old May 4, 2008 | 02:40 PM
MK 82's Avatar
MK 82
I agree!! Driving is bad enough here without encountering someone trying that procedure.
Old May 4, 2008 | 02:45 PM
CFI-EFI's Avatar
CFI-EFI
So ALL of Florida is bumper to bumper, ALL of the time? I've never done that in Utah, but I have in Chicagoland. Enjoy your laugh and thank you for the complement.
RACE ON!!!
Old May 4, 2008 | 02:53 PM
JohnyH's Avatar
JohnyH
RACE ON!!!
I've had to do this in harder times (younger years) and in heavy traffic, successfully! Now I carry CAA card, it's a godsend!
Old May 4, 2008 | 02:57 PM
toptechx6's Avatar
toptechx6
RACE ON!!!
No, of course you are right CFI, truth is there are many places in Florida that are very rural, but mostly the interior. The coastlines are packed both sides, and worse here on the Atlantic side.
Suppose I was just picturing my luck trying to pull this off, then you would be the one laughing at the huge multi-car collision you saw on network news tonight caused by some old geezer driving his Vette in Florida! Hope you understand the comment was all in fun.
Old May 4, 2008 | 09:11 PM
CFI-EFI's Avatar
CFI-EFI
I was as serious as a heart attack. The title of this thread is "Need Help Asap! Stuck On Road!". I thought I presented a viable, possible, suggestion, depending on the actual conditions, me not being there to see for myself. My thanks for the contribution is nothing but criticism. Maybe that technique is too advanced for some. There is nothing particularly hazardous about that procedure.
RACE ON!!!
Old May 4, 2008 | 09:23 PM
Road Agent's Avatar
Road Agent
RACE ON!!!
Your assuming these guys know how to drive like the kids did years ago! Better pay a flat bed then get someone hurt! Your way over their heads!
schrade's Avatar
schrade
I don't think you're sorry that you have to laugh. I think that's your way.
When OP is ready to pull the trigger - sometime on sunday night, anywhere in the US, ga$ thru the roof, he'll have little traffic to contend with, to do a pretty easy task.
NOT sorry I had to let on to ya'.
ed: why don't you get elected, and say 'no' every time some spending legislation gets voted on? We need your type in DC, and I'll vote for ya'.
To Need Help Asap! Stuck On Road!
