motive power bleeder
on the motive power bleeder, what unit do we use for these cars?
I have read there are different cap adapters and don't know what model to use.
they have the MP-0100, 0104, 0106, 0107....you get the picture
what one do we use for our cars? I am going to order me one since this seems to be the best option for brake bleeding (I have what looks like starbucks coffee in my master cylinder, time for a brake system flush)
what do you guys that have have these power bleeders recommend?
I have seen nothing bad about the power bleeder, so I am heavily leaning towards it. I am still open for debate on the subject.
I installed SpeedBleeders and also bought their little plastic bag with the bleeding hose attached - it was a breeze to bleed the brakes!
It works well, but I couldn't pump it up to the recommended pressure. When I did take it up to 20 PSI, the cap blew off. Not good. I figured out real quick that 10 to 15 PSI works great. No need to go higher PSI than that.
As for the conversation around speed bleeders verses power bleeder, I'll try to stay out of that one. Like everything else, I am sure that there are advantages either way, but I wanted to be able to do a compete flush and the power bleeder seemed to be better for that.
Here is some detailed info that I sent in a PM to a curious member:
The bleeders were $7 each for steel, but if you prefer the stainless steel ones are $15 each. Either type come with dust caps. In addition, I bought the Speedbleeder bag and hose combo for $6. The hosing could also be bought at Home Depot or Lowes, but you have to buy like 25 ft of it for $7 or so.
To install first remove the old bleeders. Since they are inserted into an aluminum caliper, they should be given a hit with a hammer to shock them. Don't hit them so hard you break the bleeder though. Then use either flare/line wrenches or Vice Grips to remove the old bleeder. The old bleeders are very easy to round-off, ask me how I know. Make sure that no debris falls into the open bleeder hole - I recommend taking a metal wirebrush to the brake bleeder area prior to removing the old ones. This will remove brake dust and any other particles in the nearby area. Hurry and install the new one as the fluid will be slowly 'bleeding' out of the caliper. Oh, and never leave the caliper dangling by the brake lines - you can seriously damage the lines.
Tighten the SpeedBleeders all the way and then loosen 1/4 to 1/2 a turn. Place one end of the hose on the bleeder and the other on the male part of the bleeder bag or old container.
To bleed just pump the brake pedal until you see no more air bubbles in the hose and new brake fluid being pumped out of the new SpeedBleeders and into the bag. If you don't buy the bag, drill a hole into a coke bottle and run the hose until it touches the bottom. That way any bubbles will be visible in the liquid when the bottle begins to fill. Don't push the pedal too far down though as some seals can be damaged, I've read.
Keep the reservoir full of new brake fluid. Always use new brake fluid. Never use a bottle that was opened more than a couple days before. Water gets into the fluid and is the enemy of brake fluid.
If you want the best fluid for your change, many forum members recommend ATE Super Blue racing brake fluid. It is a blue DOT 4 fluid. It has a super high boiling point and the color makes it easy to see when the old fluid has been swapped and for leaks. Ebay or an internet parts store is the best place to get it. The best fluid that is really easy to get a hold of would be Valvoline SynPower or Syntech, its one of those two names...You can find it at any major auto parts store. Make sure it is the synthetic, more expensive one though. The clerks will tell you the cheaper Valvoline in the white bottles is the same, but get the more expensive one. Its a brake fluid, get the better one. Its only like $4 a bottle anyways. I used 3.5 because my brakes had never been bled in 80,000 miles.
Close the bleeders of course after you're done with that caliper.
Good luck, I hope this helps in your decision. And I agree the Power Bleeder can be used on multiple vehicles, but I just liked the SpeedBleeder concept better.
Jonathan
While you're at it, you may want to check your brake lines and possibly upgrade to Earl's Stainless Steel brake lines - which I have yet to install.
Jonathan
Only need one person to do it, no pumping the brake pedal.
Jonathan
