valve cover bolt question 85
Old May 4, 2008 | 09:04 PM
viii's Avatar
viii
Default valve cover bolt question 85
Hello, I am replacing one of my valve cover gaskets again. I need some advice on the bolts. Do I clean the bolts and passages and...
Install the bolts dry...
Install with threadlocker
or Install with something else?
I am going with the felpro permadrys.
Old May 4, 2008 | 09:11 PM
John A. Marker's Avatar
John A. Marker
I will assume that you have the original cast iron heads. If you are not sure, place a magnet against the head if it sticks your have cast heads.
Clean the bolts with a wire wheel. I will often run a thread chaser into the holes to clean them up. Install dry.
If you have aluminum heads, same as above EXCEPT use anti-seize on the threads.
