Rear coolant passages
Old May 5, 2008 | 02:02 AM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Default Rear coolant passages
Why is the rear coolant passages plugged on the intake gaskets for an L98? The gaskets I'm removing from my 89 have a small hole in a metal plate (which can also be removed for more coolant flow.) Wouldn't it be better for these to be opened up? The new gaskets which are the same felpro number don't even have a metal plate, but just gasket materal altogether. Can someone explain? Thanks!
Old May 5, 2008 | 10:17 AM
Aardwolf's Avatar
Aardwolf
Are you sure you have the right gasket? I think that some of the earlier year engines don't have that back port and use the closed gasket. I have the Fel-Pro 1256 on mine with wide open ports.
Old May 5, 2008 | 12:09 PM
89Corvette6spdFX3
Uh oh, maybe they gave me the wrong one. The guy didn't seem to know what he was doing.
Is the 1256 a perfect match for the heads? If not, how do I match it?
Old May 5, 2008 | 12:28 PM
Aardwolf's Avatar
Aardwolf
The 1256 matched fine on mine, it just has the rear water passages full open. There is another gasket with the small holes in it, I don't remember the number.
Old May 5, 2008 | 01:35 PM
89Corvette6spdFX3
I would think it would be best to have full coolant flow on these engines as they seem to run pretty warm. Why would a person want the rear restricted like that?
Old May 10, 2008 | 05:15 PM
stingrayvette's Avatar
stingrayvette
Hey - I'm doing my intake gasket for an 89 L98 and have the same scenario. The gasket's have the rear water jacket blocked with an exception of a seep hole (about 1/8") and are stamped as rears. My FSM tells me to put the blocked port in the front. This does not make sense.
What did you end up doing?
Old May 10, 2008 | 08:02 PM
stingrayvette
Aardwolf - Did you have open ports from the beginning? Wondering if there was any change in the cooling going from restricted to open.
My gaskets kinda came apart during disassembly. I did find a piece of rectangle metal with a tiny hole in it but I'm not sure which passage was block, front or back so I believe I had the restricted.
Old May 10, 2008 | 08:41 PM
Aardwolf's Avatar
Aardwolf
My stock '88 intake gaskets had the small hole in the rear port. No troubles using the gasket with fully opened ports. I've debated deleting the steam vent hose but haven't.
Old May 10, 2008 | 10:02 PM
Stewball's Avatar
Stewball
I was about to post and ask the same question. The FelPro overhaul gasket set I just bought has the restrictor plate and the directions from FelPro say to use it in the back. The gasket kit I bought off ebay from some guy down in Texas had fully opened ports. I see the topic is still up for debate???
Old May 10, 2008 | 10:38 PM
rodj's Avatar
rodj
Had mine deleted for years , never had a cooling problem if "burped " correctly.
Old May 11, 2008 | 10:59 AM
Aardwolf's Avatar
Aardwolf
Good to know, do you have the full open rear ports?
Old May 12, 2008 | 03:00 AM
rodj's Avatar
rodj
No , I bought a job lot of full TPI gaskets sets so have only ever used the factory type with restrictor.
As with the other comments , are at a loss to explain why rear port is not used in our setups but have never had any cooling probs.
Touch wood.
Old May 12, 2008 | 07:59 AM
SPD KILS's Avatar
SPD KILS
My friend had his 88 motor completely rebuilt, it always ran hot. He installed a low temp fan switch and a 160 stat and it did not help. One day he decided to do a head swap. we noticed the rear water ports were restricted with a 1/8 hole. I drilled a 1/2 inch hole in the new metal block offs. The car has run cool ever since.
Old May 12, 2008 | 10:37 AM
conv90's Avatar
conv90
I always wanted to ask to you gurus..
.. I have Brodix heads with the rear coolant passages BIG and OPEN (if I correct remember..)
The Superram baseplate HAS also the rear coolant passages (if I correct remember.. ).
Obiouvsly I used gaskets (felpro 1206) with the BIG rear coolant passage OPEN.
But what I ask to myself....
What'S if I use an intake manifold without the rear coolant passage?
Where's going the coolant if the manifold don't allow the passage?
Which part of the motor will not be cooled anymore?
-Beppe-
Old May 13, 2008 | 09:31 AM
rodj's Avatar
rodj
-Beppe-
Beppe , consider this.
Where does the rear passage go?
Only from one head to the other.At best it might pickup some heat from oil splash under intake; at worst it is adding unwanted heat to the intake.
Neither my Edlebrock Torker or Vic Jnr manifolds ( both popular performance intakes ) have rear coolant crossover.I don't believe my HSR has it either.
A SBC enters water into the block at the front (waterpump ) and exits from the heads via the front intake crossover to thermo housing.The water circulates in the block meanwhile.Nothing is setup to particulary direct flow across the rear crossover from one side to the other.
Some racers run hoses direct off the rear coolant ports to get better
( more even ? ) cooling .
The LTX engines have superior cooling because the coolant is directed to the heads first where the major heat is.
Old May 13, 2008 | 09:39 AM
conv90's Avatar
conv90
Thank you Rodj, Perfect explanation!
Old May 13, 2008 | 10:26 AM
SunCr's Avatar
SunCr
Design was to keep the coolant at the rear of the heads longer to enable better cooling (and given the number of head gasket failures at #7, I often wonder how effective it was). To ensure adequate flow, coolant is delivered from the bypass at the heater core outlet. Design is unique to the Vette and wasn't used on the F Bodys, so when shopping for manifold gaskets, you need to specify that it's for a Vette, (though many have done away with it and when you do, you can plug the bypass). '91 is particularly difficult to find as the heads were also redesigned to accept intake gasket retainers and the F Body and/or ZZ4gaskets (without the restrictors) are generally all that's available. Also, for '89, ignore the Service Manual as it has the install backwards (corrected by a Bulletin).
Old May 13, 2008 | 10:48 AM
SunCr's Avatar
SunCr
PS: Here's a link with a little more: http://www.hotrodlane.cc/PDFFILES/TPIStory.pdf
Old May 14, 2008 | 01:13 AM
89Corvette6spdFX3
SunCr...thanks for the link. That's need-to-know information for anyone with a TPI car.
To Rear coolant passages
