LT4- Rev limiter?
Old Dec 16, 2001 | 03:53 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Default LT4- Rev limiter?
HI- Does anyone know for a fact if there is a rev limiter on an LT4 motor? If so, can I trust it when I drag race??
Anyway I re-programmed it using the hypertech programmer to 6400. Can I still trust it?
If it does have one what happens if I hit it? Does the motor shut down?
Thanks for your help! :chevy
[Modified by eamador11, 1:55 PM 12/16/2001]
Old Dec 16, 2001 | 04:01 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: LT4- Rev limiter? (eamador11)
If you listen carefully, you can hear me bouncing off the rev limiter here:
http://temp.corvetteforum.net/c4/mrm...akinoffbg2.mpg
I don't recommend doing it often, I think that is why my water pump went.
Old Dec 16, 2001 | 04:44 PM
GlockLT4's Avatar
GlockLT4
Default Re: LT4- Rev limiter? (Mr Mojo)
You're lucky if your water pump going is all you have wrong when you peg the rev limiter all the time.
Old Dec 16, 2001 | 06:19 PM
GS Ragtop's Avatar
GS Ragtop
From: Michigan in the summer, Florida the rest of the time
St. Jude Donor '08-'09-'11
Default Re: LT4- Rev limiter? (Glock'94)
Why's that? I thought the only thing the rev limiter did was alter the timing to detune the engine and force back the throttle cable. Doesn't sound like that would harm the engine...
Brad
Old Dec 16, 2001 | 06:28 PM
GlockLT4's Avatar
GlockLT4
Default Re: LT4- Rev limiter? (GS Ragtop)
Well, the rev limiter of the LT4 is 6300.. and I've always thought of a rev limiter as an absolute maximum for a car. Yes, it'll run a little higher than that (stock), but it's not necessarily safe. Just my opinion...
Old Dec 16, 2001 | 06:34 PM
Mr Mojo's Avatar
Mr Mojo
Curtis, I don't always peg it, but on occasion I will hit it.
Old Dec 16, 2001 | 06:47 PM
GlockLT4's Avatar
GlockLT4
Gotcha ;)
Old Dec 16, 2001 | 07:10 PM
No Go's Avatar
No Go
LT4 revlimiter is set at 6400 stock. Redline is 6300 rpm.
I run the end of my quarter mile runs on the rev limiter in third gear ~110 mph.
It cuts the fuel, but is not like hitting a wall. Is it hard on a car...well it is hard on a car to run it to redline...so hardly any more hard on it than hitting redline in my opinion.
Engines are pretty durable-mine has 73,000 miles-not cruizer ones either.
I wouldn't be holding it in neutral on it though.
[Modified by No Go, 5:11 PM 12/16/2001]
Old Dec 16, 2001 | 08:42 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
I would hope GM set the rev limiter at an rpm thats safe for the motor.
Old Dec 16, 2001 | 08:57 PM
TravisD's Avatar
TravisD
I hit the rev limiter all the time autocrossing. Small courses are frequently faster when you just stay in 1st gear. The LT4's higher rev limit means more usable engine range within a given gear.
Old Dec 16, 2001 | 09:57 PM
LT-IV's Avatar
LT-IV
Default Re: LT4- Rev limiter? (TravisD)
It's programmed to protect the engine. (And avoid warranty claims)
If the engine would be hurt by pegging the rev limiter, G.M. would have set it even lower than it is. :seeya
I have mine reprogrammed (Hypertech).
I try to shift at 200 RPM's below the limiter. Usually it works great without hitting the limit. :yesnod:
[Modified by LT-IV, 7:59 PM 12/16/2001]
Old Dec 16, 2001 | 11:51 PM
Nathan Plemons's Avatar
Nathan Plemons
You should be fine. It's really all about your valve springs more than anything. The story goes with the LT1 anyway that if you hit the rev limiter about twice you just ruined your springs. Rumor has it that they are shot after 50,000 miles. Anyway worn out springs will cost you HP and your valves will float in the higher RPM's. I've hit the limiter on mine since I've done the cam several times, being that the tach doesn't read that high. Anyway the springs are good for more than that, hell people with stock bottom ends will turn 7k. I don't think I want to, but it can be done.
If it really worries you I would buy an MSD box or something just so you have a better rev limiter. These can be set to whatever you want and they drop the spark rather than fuel, which is much better on the motor. Just set it about 100 rpms before the factory limit.
Old Dec 17, 2001 | 01:17 AM
NotSlo's Avatar
NotSlo
Elite Member
Cruise-In III Veteran
St. Jude Donor '09
I know I've hit mine a few times! ;)
[Modified by NotSlo, 12:17 AM 12/17/2001]
Old Dec 17, 2001 | 02:39 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: LT4- Rev limiter? (NotSlo)
Guess that's what happened to my waterpump too! :crazy:
BTW I got this from
http://vette.ohioracing.com/majmods.html
Gee what's that knocking noise?. The motor blew right at the finish line of an autocross event in the middle of nowhere Michigan. Of course right at the height of race season and one day after I had just spent big bucks on 4.09 gears. I broke my vette and Al Murrel, a fellow competitor, hauled me home. Thanks Al! You have an invitation to co-drive my car! Also, I owe thanks to John & Debbie Fessler, and Paul Wines for hauling my tire trailer home.
A word of warning, 6200 RPM is the Limit for a stock LT1. I set my rev limiter to 6400 RPM against the advice of Justin Vandersall (Superman Vette Mechanic). The motor lasted for maybe 10 revs at that limit. The LT1 rod caps can not take high RPMs. The cap on the number six cylinder stretched. The piston began to slap against the head when down revving. As soon as the engine cooled the bearing spun.
sound familiar to anyone?!!
[Modified by BrianCunningham, 1:44 PM 12/17/2001]
To LT4- Rev limiter?
