85 Digital Dash
Old May 6, 2008 | 08:03 PM
selkirk24's Avatar
selkirk24
Default 85 Digital Dash
Hope someone may be able to help me out on this. All my dash lights went out yesterday, the LCD's are still working, but the 4 lights that are used to backlight do not come on. Is no the usual ground problem, ie, turn signal and hight beam light staying on. I Have checked the ground pin on the connector to the dash, it is fine. Have also checked the hot wire coming into the connector, and am getting voltage on that also.
Does this mean my dash is fried?
Hope not, maybe there is a somewhat simple fix for this. Any help would be appreciated.
Old May 6, 2008 | 08:49 PM
Eddywill's Avatar
Eddywill
hmm may have fried a line on the board that feeds the lights - not too hard to fix if you are handy with a multimeter and a soldering iron. You may actually see the issue and be able to put a jumper over the fried spot. But then again you may just need 4 bulbs (if all four burned out at once go buy a lottery ticket - you are due)
