Engine problem?
Old May 6, 2008 | 09:39 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Default Engine problem?
I was headin out to the beach the other day and the engine started acting wierd.
L83 Crossfire
There is a ticking from what sounds like under the left side valve cover. The exhaust started sounding like I had a high profile cam. And some power was gone. The problem has been coming and going for 2 or 3 days now. The oil is good, hasen't overheated or anything.
I was thinking that possibly one of my injectors wasn't fireing right. But they are both flowing good. Could it be a rocker arm? Spring? Sparkplus not fireing right? Any help would be awesome
Old May 7, 2008 | 10:35 AM
NEVRL8T's Avatar
NEVRL8T
I have an LT1 and when my car did that right before I broke a valve spring. I mean mine did EXACTLY that.
Old May 7, 2008 | 11:35 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
If you think it is coming from under a valve cover, pull it and have a look.
Old May 7, 2008 | 11:48 AM
Deakins's Avatar
Deakins
It could be a lifter that is not holding pressure giving your engine too much valve lash and costing you lift. Pull the cover and see if there is excess clearance and go from there.
Old May 7, 2008 | 07:58 PM
JackDidley's Avatar
JackDidley
STOP driving it before a valve drops into the cylinder and destroys everthing.
Old May 7, 2008 | 10:01 PM
cv67's Avatar
cv67
St. Jude Donor '05
have someone take a peek at it and see what they can find.
Id bet money you have a cam going flat. 84 right?
Old May 7, 2008 | 11:08 PM
redsox's Avatar
redsox
Cruising
That happened on my 85 and it was a rocker arm stud pulling out of the head.
Old May 7, 2008 | 11:51 PM
Grease Monkey
Thanks everyone. I will pull it sometime this weekend and take a peek .
Anyone know the proper clearences? Should I just check it vs. the other side?
To Engine problem?
