lowering 93
All the DIY posts show the new lowering kit shims glued FLAT SIDE AGAINST THE SPRING ( triangle of wedge pointing up into the frame)(and reusing the flat aluminum shim).
On the MAM instruction sheet is says to mount the poly shims INTO THE FRAME, FLAT SIDE UP (triangle of wedge bearing onto the spring)(and remove the flat aluminum shim.
That is quite a difference in technique. If anyone can offer an opinion it would be appreciated. It is kind of late because it's already done but if I have to we can grind the shims out of the frame recess and turn things around. (I have another set of shims)
The mechanic that did the work read the instructions several times and compared that info to the DIY posts. He is of the opinion the DIY sites have miss read the MAM instructions. He offered some convincing logic!
Thanks in advance. No trash talk thanks just considered input.
However, I would imagine that it should work either way. The same principle applies to both techniques. My only worry would be positioning it correctly on the frame. On the spring, it's easy to get them purchased perfectly; it's right where the old rubber things were!
http://webpages.charter.net/khasting.../lowering.html
The link you sent is the one that shows the aluminum shim being returned into service. As we discussed it we couldn't see the point of returning the shim. As you pointed out it pretty much nullifies the whole effort of removing the pads etc.
Thanks for the input. I'm breathing a little easier. I think the car goes in for alignment tonight.
The mechanic pointed out that by turning wedge down it significantly ( because of the tremendous spring pressure) changes the torquing moment on the spring and allows to car to sit lower.
