Traction Control retard
Old Dec 17, 2001 | 04:54 AM
GlockLT4's Avatar
GlockLT4
Default Traction Control retard
What is a good table of traction control retard values? I figure 0-800rpm only needs 4deg since the car shouldn't ever lose grip then.
The times that I've lost traction (and needed it), I'm pushing it harder than I should on a wet surface, and I'm guessing my rpm's are around 1200-2500. The stock values are
1200- 25deg
1600- 30deg
2000- 31deg
2400- 32deg
When it does kick in, it REALLY kills the throttle... should i reduce these about 5deg? How much of a difference would 5deg make? I've found a few .bin from Ed Wright on misc internet sites and the retard is only 4 degrees all the way across the rpm range (which to me seems like it's just turning traction control off almost completely).
I know how to recover from the back end losing it, but I'd rather not have to worry about that sometimes as I can't detect it before the computer can. I usually only leave ASR on when it's wet out anyway, but even then I think that it retards a little too much.
[Modified by Glock'94, 2:57 AM 12/17/2001]
[Modified by Glock'94, 10:46 AM 12/17/2001]
Old Dec 17, 2001 | 09:17 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: Traction Control retard (Glock'94)
I would just try cutting those values in half maybe. I wouldn't disable it all together, that's what the button on the dash is for! You may wish you still had it when you get caught in an ice storm or something..... I drive my car everyday, and last winter a bad freeze came up at 3 in the afternoon, and by 5 it was pretty bad. My 4 mile trip home took over 30 minutes waiting in line idling down the road.
Old Dec 17, 2001 | 12:45 PM
GlockLT4's Avatar
GlockLT4
Default Re: Traction Control retard (Marcho Polo)
I'm going to try about 33% off of those values and by the time I finally get all this together and working I can try it out on a rainy day and see exactly how much 5-10 deg of retard effects controling the car still. thanks marcho :)
Old Dec 17, 2001 | 09:08 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I'll say, it almost put a passenger through the windsheild once! :mad
I'll be watching this thread.
Old Dec 20, 2001 | 08:54 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Your system must be different from mine. My ASR always detects wet wheelspin after I have eased off the throttle. I usually end up fighting it once it kicks in. Try accelerating from gravel with it and have it kick in once you get on the road.
I'd leave it the way it is if you want it to be effective, otherwise use the values in the modified chip you found.
To Traction Control retard
