Not doing well on the general forum, so will try here. When did Brake Horse Power become Horse Power? Horse Power is the engine size 12 H.P. = 1200cc. 10 H.P. =1000cc. etc. B.H.P. is the amount of brake power required at the crank or rear wheels (obviously different figures) to stop the engine whilst it is at full power. How about we all start using the correct term.
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
This is going to end well, I am actually shaking in anticipation for the responses....
In the United States the term "bhp" fell into disuse after the American Society of Automotive Engineers (SAE) recommended manufacturers use hp (SAE) to indicate the net power of the engine, given that particular car's complete engine installation. It measures engine power at the flywheel, not counting transmission losses (or anything after the flywheel). Starting in 1971 automakers began to quote power in terms of SAE net horsepower.
Yes your engine has 57 horses, a Mini would have had between 7.5 and 12.5 depending on model. SAE recommendations gave a false indication of a cars performance level by inflating a figure that many people thought indicated its capabilities. i.e. The more it has the better it is.
HUH? Hp has nothing to do with engine displacement. It is a direct calculation given Torque at a certain RPM. HP = (Torque x RPM)/5252. That's all there is to it. I think the torque an engine puts out is pretty obvious where that comes from. I don't know where you got your information from but, uh, it's wrong.
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Displacement matters not.
Horsepower was coined by J. Watt as an estimate of how much weight a horse could pull in a given amount of time.
Additionally, since hp was/is/and will always be in English units, how the hell do you expect it to line up with metric units (cc's).
The only think I can think of is that your confusing Liters.
I don't know who pulled a joke on you, but you've been had.
If you have some other credible source for this, I'd love to see it.
In the mean time, I won't hold my breath.
I would TRY to explain this to you in DETAIL however you are so lost I don't know where to begin. If you are SERIOUS which I SERIOUSLY doubt you should use the internet to read up on the subject rather than post this as FACT on a TECH forum.
He actually counted the steps of a quarter horse to lift a weight a measured distance. I think it was 12,000 steps, I can't recall the distance. Germans used a draft horse to get their calculations (stronger horse) for diesel engines. The calculation for measuring diesel horsepower is less the 12K.
I agree. Poster is phishing for controversy. Tie him to a horse and slap it's rump
