Hypertech - to be or not to be
Old Dec 17, 2001 | 08:23 AM
Cratzy's Avatar
Cratzy
Default Hypertech - to be or not to be
I've reading some topics about the Hypertech chip on a stock engine, and it doesn't seem like a good investment.
However my engine is a bit modified with headers, K&N and AFPR, 2xCatco 2,5" catalytic converters and a 3" exhaust system, 160degrees thermostat. I have already ordered a Hypertech Stage II chip. Will it do anything good for me or should I send it back?
Thanks in advance
:confused:
Old Dec 17, 2001 | 08:43 AM
ncChris's Avatar
ncChris
Default Re: Hypertech - to be or not to be (Cratzy)
Send it back..with slight mods the hypertech actually slowed me down....
It is way too generic but handy if u change gear ratios or lower cooling temps..
i know of no Corvette that ran faster using Hypertech. I do know of 4 Corvettes that ran worse after installing the Hypertech. Your best bet is to
contact ChrisK at speed demon motorsports and let him set up ur program..
GL.........Chris
Old Dec 17, 2001 | 09:35 AM
Cratzy's Avatar
Cratzy
Default Re: Hypertech - to be or not to be (ncChris)
But with the 160 degrees thermostat I will have a lower cooling temp and then I can gain some with the Hypertech, or...?
Old Dec 17, 2001 | 09:50 AM
Nathan Plemons's Avatar
Nathan Plemons
By no means will it slow you down. A lot of people who say it does don't do
any comparisons in comprable weather. IE, I could run a 13.2, but with the hypertech in completely different track conditions I couldn't get any traction and I can only run a 13.9.
That's what you'll see a lot of. I don't think it good for much anything other than lowering temps as you say, but it shouldn't hurt. I've yet to see anybody with dyno numbers to prove that it hurt them. However I've never seen anybody with dyno numbers to prove that it helped them either.
[Modified by Nathan Plemons, 7:50 AM 12/17/2001]
Old Dec 17, 2001 | 11:59 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Hypertech - to be or not to be (Nathan Plemons)
I'd go with a chip that you can get free new chips burned as you add mods. I read somewhere that there are a few guys out there that will "update" your chip based on new changes you made. If Hypertech does this, maybe its worth a try. The best bet would be to get an ECM in there from a 94+ so its programable. Does anyone know if you can plug a newer one right in or are the harnesses different?
Old Dec 17, 2001 | 01:48 PM
GlockLT4's Avatar
GlockLT4
Default Re: Hypertech - to be or not to be (92TripleBlack)
Skip the hypertech and save your cash to buy your own software and make your own program customized to your vette... don't use the hyper tech, definitely NOT worth the $$$!!!
Old Dec 17, 2001 | 04:16 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Of course it can slow you down!! If it's not tuned to your setup or does something such as add too much timing, it's not going to make the car run any better...
Read the 5th post down on this thread: http://forums.corvetteforum.com/zerothread?id=201295
Vic's 89 ran 2 tenths slower by adding an aftermarket chip... and he tested both chips out while at the track in a single day...
Old Dec 17, 2001 | 04:21 PM
Nathan Plemons
Default Re: Hypertech - to be or not to be (Springer's 95)
Yes, but by that line of reasoning you are throwing in mods. We were originally talking about something fairly stock were we not?
Old Dec 17, 2001 | 04:26 PM
Springer's LT4
Cratzy's car isn't any more stock then Vic's car is... both have some decent mods done to them.
Old Dec 18, 2001 | 03:24 AM
Cratzy's Avatar
Cratzy
Since I have already bought the chip I guess I will have to try it and see for my self. Perhaps I can find some poor guy here in Sweden that I can sell it to :D
What about Ed Wright chip, I've seen alot of people here using it?
To Hypertech - to be or not to be
