Another WTF was I thinking
Old May 9, 2008 | 11:10 PM
Livin the Dream's Avatar
Livin the Dream
Default Another WTF was I thinking
Or oops I forgot to check all the fittings
Tonight while contemplating a major tune up I was poking around near my distributor. Touched the hard vacuum line going to brake booster and it was loose! Found it about 2 turns from being tight at the plenum- guess I forgot it last summer when I changed the injectors. Car has been running fine , but its hard to believe I didn't cause some unwanted idle/fuel problems. Not sure how much it was leaking or should I say sucking air into the plenum but I know I am going to go back and set the IAC and TPS again just to be sure . Any other ideas?
Old May 10, 2008 | 12:03 AM
John A. Marker's Avatar
John A. Marker
Check timing while your at it.
