87 wheels
Old May 10, 2008 | 07:25 PM
Jim D's Avatar
Jim D
Default 87 wheels
Here is what Jim knows about wheels=0 . I'm tired bottoming out the car. I think its hitting the spare tire carrier . Have new shocks on. Here is the question, can I buy a wheel with my offset that will take larger tires. Thanks in advance, Jim.
Old May 10, 2008 | 07:52 PM
c4cruiser's Avatar
c4cruiser
Have you looked under the car to make sure the spare tire carrier is sitting in the upper notches? There are two sets of notches; one is for the skinny spare tire (highest) and the other is for carrying the road wheel (lowest). The difference is about 3 inches and that could be the problem.
Other issues could be a spring that has delaminated or cracked.
Taller tires won't really help if there is a spring problem. And taller tires will throw off the speedo readout.
Old May 11, 2008 | 01:20 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Also check your suspension for problems. But i agree with C4, i'd check the tire carrier first, there should be no issue with stock wheels, or maybe an issue with your driving style...
And Taller wheels will do NOTHING, but clean out your cash
To 87 wheels
