What exactly does the AIR system do ???
Old Dec 17, 2001 | 03:52 PM
Arisa's Avatar
Arisa
Default What exactly does the AIR system do ???
I assume that the metal lines that go into the tops of my exhaust manafolds are for the AIR system. What is this, what does it do, & is it needed.
NOTE: LT4 engine !!!!!!!!! (so no EGR)
Neal
Old Dec 17, 2001 | 04:06 PM
GRX's Avatar
GRX
Default Re: What exactly does the AIR system do ??? (Arisa)
Injects air into the exhaust stream so unburned fuel can continue to burn THUS, reducing unburned exhaust emmisions.
[Modified by GRX, 12:08 PM 12/17/2001]
Old Dec 17, 2001 | 04:36 PM
Nathan Plemons's Avatar
Nathan Plemons
It clutters up your engine compartment and makes it harder to get at the valve covers ;)
Old Dec 17, 2001 | 05:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It does those things but mainly it provides air to burn HCs in the exhaust manifold during warm up to quickly bring the O2 sensor (and maybe the cat too) up to operaring temp. After the ECM goes closed loop the air is diverted soley to the cat.
It should be possible to plug the AIR fittings in the exhaust manifold and run a heated O2 sensor with only slightly higher HCs during warm up. Though it's illegal to do this mod without your state's permission/exemption.
[Modified by 65Z01, 3:10 PM 12/17/2001]
Old Dec 17, 2001 | 07:23 PM
84corvette's Avatar
84corvette
Just thought I would add that it is an accronym for "Air Injection Reaction" (isn't that clever??) Those engineers --They have to make the big bucks somehow!
Old Dec 18, 2001 | 01:48 AM
GlockLT4's Avatar
GlockLT4
Default Re: What exactly does the AIR system do ??? (Nathan Plemons)
:lol: :yesnod: :yesnod: :yesnod:
To What exactly does the AIR system do ???
