Tire size for a 87
Old May 12, 2008 | 03:24 PM
e-vette39's Avatar
e-vette39
Default Tire size for a 87
What is the smallest and largest size tire for the front and rear of a 87 vette.
Old May 12, 2008 | 04:50 PM
Square's Avatar
Square
Stock wheels?
I have seen an 86' with 11" ZR-1 "A-mold" wheels on all 4 corners with 315/35-17 tires. I believe there rubbing issues with hard turning at that size. I have AFS ZR-1 wheels with 275/40-17's inthe front and 315/35-17's inthe rear with no rubbing issues.
Old May 12, 2008 | 06:55 PM
c4cruiser's Avatar
c4cruiser
What wheel diameter? The wheel size makes a difference as the section width and aspect ratio of the tire changes as the wheel diameter does if you want the same tire diameter as a stock wheel/tire.
You can go to a 20" wheel as long as the tire is not too wide (say 11-12 inches) and the tire diameter is around 25-26.5".
The wheel offset and backspacing also plays a part in where the wheel sits in the fenderwell.
Old May 13, 2008 | 02:10 AM
Johns87's Avatar
Johns87
with Square!
I have the same size, wheel setup on my 87 convertible with no trouble.
Check your shocks out. I new a guy who used the same setup and scrubbed the fronts a little while hard-cornering. It turned out his shocks were completely gone and the front dived when he cornered at speed(H@ll, his car was about an inch or more low at REST!!!!).
Take Care, -John
Old May 13, 2008 | 04:00 PM
Demonic85's Avatar
Demonic85
stock size is 255/50/16
Smallest size is what ever will bolt on, 15" is pretty common. The largest wheels would probably be 20's and thats pushing it. They might rub a little.
Old May 13, 2008 | 04:08 PM
racebum's Avatar
racebum
15" wheel on the back with a 28" super swamper, raise the back as high as you can with the bolts and take the car to a farmers field, make a video and post it on the fourm
To Tire size for a 87
