egr pipe removal
Old May 14, 2008 | 04:10 PM
RG86VET's Avatar
RG86VET
Default egr pipe removal
is their a easy way to remove the egr pipe on a 86, the top looks like normal torx bits but in having a issue with removing the bottom where the flange is, do i need a special tool to remove that ring and can i reuse the ring
Old May 14, 2008 | 04:26 PM
Square's Avatar
Square
I cut throught the ring with a dremel tool.
I do not believe you can reuse the ring.
A new ring is $5-6 from one of the Corvette suppliers (I know Corvette Central has it, I believe all the others do as well).
They make a tool (I believe it is called "Side jaw pliers") to crimp the ring.
I included the tool I used and how I used it at the bottom of my intake manifold install photo doc, here:
http://members.***.net/effergyvette/...e_install.html
