L98 Buildup questions
Old May 14, 2008 | 10:53 PM
ironmike07's Avatar
ironmike07
Default L98 Buildup questions
I am currently building up the tired old L98 in my 1990. I ordered up the cast iron vortec heads (more flow at a great price). A half-inch comp cam valvetrain kit, and I'm planning on swapping the tpi out for a carburated setup (much more cost effective...even if the gas mileage is gonna suck.) I'm just wondering if you guys have any other suggestions for what I could add into this build up.
p.s. I have about a grand left in my budget.
Old May 14, 2008 | 11:00 PM
PurtyLilC4's Avatar
PurtyLilC4
a free flowing exhaust if you don't already have one
Old May 14, 2008 | 11:04 PM
ironmike07's Avatar
ironmike07
Yeah, I already have a set of hooker long tube headers and true dual exhaust.
Old May 14, 2008 | 11:06 PM
ironmike07's Avatar
ironmike07
Also, my goal at the end up the project is to add about 100-150 hp over stock. Any help is much appreciated.
Old May 15, 2008 | 01:15 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Even more cost effective would be to try the siamese intake base from stock base and runners. It will flatten out the power curve and nicely extend high end power.
Old May 15, 2008 | 01:37 AM
ironmike07's Avatar
ironmike07
I checked on the manifold and runner from TPiS. They want 475 for the runners and about 375 for the manifold. Plus with the cam and heads it's gonna cost about 600 for a custom ecu chip. That's really one of the biggest things that pushed me towards just doing the carb setup. I do appreciate the input though, thanx.
I don't spose you would know what kind've fuel pump I would need, sayin that I were to get a 650 cfm?
Old May 15, 2008 | 02:20 AM
cv67's Avatar
cv67
St. Jude Donor '05
Just ported a set of Iron Vortecs, they are being flowed.
Heard good things about them, we will see.
Sure you are aware you lose your EGR, right?
If you can use a manual FP I have a brand new Holley HP mech pump in the box I cant use....
Old May 15, 2008 | 02:30 AM
ironmike07's Avatar
ironmike07
I was going to have mine ported but the local machine shop wants an outrageous price. I think stock vortec flow will work for right now. Why do I need to worry about losing my EGR? (not being a smartazz)
I'll check about the pump. If I can use it than I'd definitely be interested in buyin that pump off ya.
Also, what would be a good gear ratio to go with for my 1990 w/6-speed?
Old May 15, 2008 | 02:48 AM
cv67's Avatar
cv67
St. Jude Donor '05
In progress...
Yeah, I know my camera sucks too.
Old May 15, 2008 | 02:57 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I would just put a zz4 in it ,cheap and almost 400 hp
Old May 15, 2008 | 03:23 AM
ironmike07's Avatar
ironmike07
I checked out the zz4 but I think the cam I've got will work nicely on the setup so far. I don't spose anybody would know anything about what the L98 bottom ends stand up during NOS applications?
Old May 15, 2008 | 07:49 AM
Iroc57's Avatar
Iroc57
Just keep running the stock pump. I used the mallory regulator with return and have a constant 6psi to the carb.
Old May 15, 2008 | 08:01 AM
ironmike07's Avatar
ironmike07
Many thanks.
Old May 15, 2008 | 01:32 PM
Master__Shake_'s Avatar
Master__Shake_
I plan on swapping out to carb as well, but would suggest higher than 650cfm. Get a 750 double pump and jet it down, just incase you plan on going higher numbers down the road.
How do those heads flow at 6k+ RPM?
Old May 15, 2008 | 05:21 PM
REDC4CORVETTE
I juiced my 86 l98 to 150 shot before I blew it .
Best thing that ever happened to that motor .
I have a 434 in it now and a built 700r4 and carcreations rear running 9's.
Just a little u u unfriendly on the street
Old May 15, 2008 | 05:34 PM
Iroc57's Avatar
Iroc57
I have to disagree with this one
I run a 750 on my 454 and it feeds it fine so the 650 should be plenty
Old May 15, 2008 | 05:50 PM
cv67's Avatar
cv67
St. Jude Donor '05
Would prefer the snappiness of the 650 and jet it up rather than a 750 if its a mild street motor.
To L98 Buildup questions
Old May 15, 2008 | 09:25 PM
PurtyLilC4's Avatar
PurtyLilC4
I know in our 90 L98s we have forged flat top pistons that boosted the compression to 10.25:1, I have a buddy that runs a 75 shot on his 91 stock bottom which is the same as the 90 and hasn't had any problems
Old May 15, 2008 | 11:12 PM
hobby0002000's Avatar
hobby0002000
Might want to check into the Demon carbs with an annular booster, I think a speed demon is for durations between 220-240 @.050 duration cams.
Old May 16, 2008 | 12:01 AM
sharp90's Avatar
sharp90
In progress...
what's all the gunk on the floor?
