6speed with 3.73
Old May 15, 2008 | 01:33 PM
atlow8's Avatar
atlow8
Default 6speed with 3.73
Thinking of changing 1989 auto trans with 3.73 rear end to 6 speed manual trans. Do I need to change the 3.73 rear end, what are the pro's and con's to this setup if possible? Thanks, Sean
Old May 15, 2008 | 01:48 PM
STL94LT1's Avatar
STL94LT1
3.73 gears work well with a 6 speed.
Old May 15, 2008 | 05:06 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
If your rear in the car is still a Dana 36, it won't stand up to the abuse it will receive from a stick.
Besides that, a 3.73 or 4.10 would work very well with a 6spd.
Old May 15, 2008 | 08:25 PM
PurtyLilC4's Avatar
PurtyLilC4
my problem was choosing between the 3.73 and 4.10, I ended up with a 3.90 and love it
Old May 15, 2008 | 09:56 PM
BLWN BUX's Avatar
BLWN BUX
If you considering a swap to ZF, I can tell you it is a lot of work!!!
Fabrication includes tunnel modification that require cutting and re-fiberglass work to make room needed for the ZF shifter.
You may PM Me if you decide to go through with it. I have pics and I can save you some frustration.
I did mine and love it!!
I only have 3:07 in now but I want to change to 3:73's
In fact I would go lower like 3.90 or 4.11 but I think 3.73 is it for a D36.
The ZF has a 2:1 Overdrive (.5)
3.73 will only be turning like 1700 RPM at 70 MPH. With 4.11's you would only be turning 1900 RPM.
Old May 18, 2008 | 11:01 AM
jacksdad's Avatar
jacksdad
I did the swap,new zf for $1500.i used 373's
i think 390's would be better.swap was a
lot of work but easy if you are good with
your hands.also central coaster helped
with info.
To 6speed with 3.73
