to the dark side!!
Old May 17, 2008 | 11:46 AM
crossfire84's Avatar
crossfire84
Default to the dark side!!
this week-end, I am removing the tpi and going to carb and manifold. If the lifters look bad, i'm sure they will, a new cam,lifters and timing chain will be required. If I remove the computor, what kinds of problems will I create? Will the dash gauges still work? and about the converter lock-up? All help will be appreciated thanks John
Old May 17, 2008 | 11:55 AM
Happydad's Avatar
Happydad
Welcome to the "Dark Side"
Yes... your dash will work..except for distance to mile empty stuff
No... your TC will not lock up..You'll need a kit for the ..Superior makes one pretty cheap and easy
Now... put your Flame suit on and get busy
Old May 17, 2008 | 05:44 PM
hexane's Avatar
hexane
As far as simplicity, you will love the carb! A nice cam will also spice up your life as well as give you at least 50 extra hp as long as you got headers. What carb and intake are you using?
Old May 17, 2008 | 07:57 PM
84REDCROSSFIRE's Avatar
84REDCROSSFIRE
Welcome too the DARKSIDE
My CFI runs so much better sitting on the floor of my garage, and a Edelbrock sitting on top of the engine
Old May 17, 2008 | 09:09 PM
crossfire84
for the conversion the manifold is a holley contender 300-36, carb 3310-2 or 3, a set of hooker super comp headers, cam of .465/.488 lift and duration of 224/234 and 112LC. the car is a early 86 production vette. Hope this is a good combo, if not, recomendations is appreciated.
Old May 17, 2008 | 09:40 PM
1985 Corvette's Avatar
1985 Corvette
I've never paid close attention to the details but is it a direct drop in and go project? What things have to be changed when switching to a carb?
Old May 17, 2008 | 10:04 PM
crossfire84
this is my first!! the manifold and carb,looks to be a no brainer. use a early type distributor, fuel pressure regulator w/fuel return, a throttle arm corrector on the carb, linkage adaptor for the throttle cable and the tv cable. correct linkage for the tv cable is a must if you don't want to burn up the trans. fab fuel lines, low rise manifold, or hi-rise and cut a hole in hood. then you need a hood scoop, and other misc. items. I think it will be an easy conversion, if you pay attention to detail!!
Old May 17, 2008 | 10:05 PM
crossfire84
forgot, a TC lock up kit !!
To to the dark side!!
