weatherstrip install HELP!!!!
Old May 17, 2008 | 12:46 PM
ARMAN72's Avatar
ARMAN72
Default weatherstrip install HELP!!!!
OK I just got my new header front weatherstrip in from Wilcox, I did a search to look up the best way to tackle this job. I found some good advice but i got a few questions. I read some guys talkin about the clips? Where are these clips? do you reuse your old one?( I didnt get new ones with the WS.) Also I seen some used the weatherstripping adhesive some didnt. Is it a good idea not too? or should I? Final this is my 1st time doing this job and i am kinda worried about messing it up so and advice welcome ...THANKS
Old May 17, 2008 | 11:35 PM
LT1 Spirit's Avatar
LT1 Spirit
I just did all my weatherstripping except for the hatch. It was the first time I did it so I was not to sure either. The only clips I can think of are the little black push buttons at the top of each corner and at the bottom by the top of the door. I used a window and door clear silicone just where it was needed. when I pulled off the old stuff there was adhesive in a few spots. It took some time to get all of the old weatherstripping and adhesive off. I hope this helps
