Rough Idle & sparks knocks
Old May 17, 2008 | 01:34 PM
$300vett's Avatar
$300vett
Default Rough Idle & sparks knocks
Ok-- Just changed out my MAF-plugs-wires-and my CTS.. now I have a rough idle (it jumps from 4400 to 7200 rpm's) and a small miss during normal driving conditions-- the miss seems to go away around 2500 rpm's but it also starts to spark knock around 3000 rpm's . Thanks $300vett
Old May 18, 2008 | 10:25 AM
SAY WHEN's Avatar
SAY WHEN
Default crossed wires
Get out your FSM---Check the firing order--sounds like you have crossed a couple of your plug wires---and due the lack of info posted by some owners on these threads---I say crossed plug wires ASSUMING You didn't replace these parts --trying to fix this already existing problem.
Old May 18, 2008 | 05:40 PM
$300vett's Avatar
$300vett
Thanks--checked all plugs and timing-- Had a code 44 come up -- replaced the O2 sensor-- didn't help-- I guess the ECM is next-- any suggestion before I change the ECM???
Thanks again for all the help
To Rough Idle & sparks knocks
