For the 50 millionth time :help:
Old May 17, 2008 | 05:55 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Default For the 50 millionth time :help:
89 Coupe, no heater core, don't care if there is heat to my oil cooler,
and I'd like to bypass the throttle body. I'm confused as all hell where
to run to and from. Should I just run from the horizontal nipple that
points to the passenger side off the water pump to the nipple that
points forward off the intake?
Please help!
Old May 17, 2008 | 06:03 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
See where the hoses go into and out of the TB?
Connect those together, or run a new hose from where those 2 enter the rest of the system.
Old May 17, 2008 | 06:15 PM
'Shifter's Avatar
'Shifter
NCM Member '09
OK, what about the t-from the water
pump nipple,,,that goes to the oil cooler, right?
Old May 17, 2008 | 06:30 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Just run a hose from the nipple in the intake to the hard line on the pass.inner fender.
Oooops, no heater core. Go from intake nipple to waterpump nipple.
'Shifter's Avatar
'Shifter
NCM Member '09
Imagine my suprise when I pulled the hose off the water pump nipple,
and coolant kept leaking forever...
Another reason for removing the long hoses, first: they don't do any-
thing now that my heater core is dead, second: in Arizona, we have
heat issues, never cold-I don't need heat to my oil cooler base, if
that is where that pipe goes...
Old May 17, 2008 | 06:32 PM
'Shifter's Avatar
'Shifter
NCM Member '09
What hard line on the inner fender? Closest thing I see is down low under the a/c compressor....and what about the nipple on the water pump?
Old May 17, 2008 | 07:14 PM
'Shifter's Avatar
'Shifter
NCM Member '09
Another thing....can I remove that small coolant line that goes to the
back of the intake (it used to t into the heater hose)...
After searching more and more, I see that member hooblyboobly has
plugged all of the heater hose ports, which I can do, but still no
mention of this little line...
Old May 17, 2008 | 08:33 PM
'Shifter's Avatar
'Shifter
NCM Member '09
Old May 17, 2008 | 09:41 PM
_twisted_'s Avatar
_twisted_
that little line actually burps the system - you can put a vacuum cap with a zip tie to hold it on there
that is the highest part of the cooling system on a tpi
Old May 17, 2008 | 10:07 PM
'Shifter's Avatar
'Shifter
NCM Member '09
A zip-tie? Serious? Seem like it would blow that right off?
Thanks for responding!
Old May 17, 2008 | 10:12 PM
schrade's Avatar
schrade
If a vacuum cap worked on his, good FOR him.
A vacuum cap is thinner, and is gonna' 'pull' onto the orifice by air vacuum - negative pressure.
Coolant is POSITIVE pressure. PLUS HEAT! I wouldn't go that way.
Old May 17, 2008 | 10:15 PM
schrade's Avatar
schrade
If re-routing all your coolant lines ain't right after 50 million tries, or even half a dozen tries, why not restore the original configuration?
Reducing the volume of coolant doesn't help cooling very much.
Old May 17, 2008 | 10:29 PM
'Shifter's Avatar
'Shifter
NCM Member '09
I guess I need to clarify...I meant the number of throttle body bypass threads that we have...
My heater core is shot, and it's a weekend car in Arizona, so I'll never
need a heater anyway. I also want to bypass the throttle body, and
I want to get rid of all of the heater hoses to clean things up.
Old May 17, 2008 | 11:15 PM
_twisted_'s Avatar
_twisted_
let me restate that, I used a vacuum plug - they are a heavier duty rubber not the cheapo colored versions.
Shifter, if your not confident with a zip tie, use a hose clamp, the smalll ones for fuel injection will work nicely.
Old May 18, 2008 | 11:29 AM
'Shifter's Avatar
'Shifter
NCM Member '09
I'm understanding that that line is to heat the EGR solenoid to 176 degrees...I have to pass emmisions, but it's usually hot when I go anyway....is plugging it going to affect driveability?
To For the 50 millionth time :help:
