[Paging]: Vette92
Old Dec 18, 2001 | 02:44 PM
scorp508's Avatar
scorp508
Default [Paging]: Vette92
I see in the above picture you have what looks to be some LEDs mounted inside the gauge pod also. I'm looking to put a couple in there myself, and a switch for my fans. Is there much room to work with inside the pod?
Thanks!!
Old Dec 18, 2001 | 04:27 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: [Paging]: Vette92 (scorp508)
There is quite a bit of room in there. Plenty for a few lights assuming they are not real long and you are using a relatively small guage wire. Those are just some lights I got from Radio Shack. Mine are mostly used for Nitrous arming and activations.
Old Dec 18, 2001 | 04:41 PM
-=Jeff=-'s Avatar
-=Jeff=-
What Gauge is that in front of the Stock Tach? Aftermarket Tach? if so do you have the PN?
Thanks!!
To [Paging]: Vette92
