Auto box speedo sensor seal
Old May 20, 2008 | 08:22 AM
ukpete's Avatar
ukpete
Default Auto box speedo sensor seal
Just replaced the tail shaft seal on my 94 auto, but have noticed a small leak from the speed sensor unit where it fits into the gearbox housing. I don't have a factory manual, is seal easy to change and do I need to take any precautions before removing the sensor???
Old May 20, 2008 | 10:27 AM
toptechx6's Avatar
toptechx6
Just the one bolt you see then pull to remove the sensor, the O ring is
PN 15552872, doubt you will lose more than a few ounces of fluid.
Old May 20, 2008 | 11:48 AM
ukpete's Avatar
ukpete
Old May 20, 2008 | 09:31 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Ijust replaced the o-ring on mine a few weeks ago. Very simple.
Take out the 10mm bolt, twist and pull the sensor out. Have a pan under it, although not much comes out. Replace the o-ring and slide it back in. Done.
To Auto box speedo sensor seal
