injector resistance readings
Old May 20, 2008 | 09:47 PM
blck90vette's Avatar
blck90vette
Default injector resistance readings
can 1 take an ohm reading to the injectors with the car not running/or ignition switch on??? seems my mechanic is telling me he can`t because he needs power /or ground to the injectors,,is he right?
Old May 20, 2008 | 10:05 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
He is full of it. Turn it off after full warm up, measure between contacts on each injector and record the reading. Let the engine cool completely and take the readings again. You don't need power for a resistance reading.
Old May 20, 2008 | 10:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
is he right?
Short answer==NO!
...measure between contacts on each injector and record the reading.
If high impedence type, all should read 14 Ohms, +/- a copla ohms.
Old May 20, 2008 | 10:18 PM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
Find another mechanic if he doesn't know how to read ohms.
Kevin
Old May 20, 2008 | 10:26 PM
RACER 1993's Avatar
RACER 1993
I did notice a small diference taking the readings after injectors were hot, from the cold readings Better readings HOT.
You can't take Ohmeter readings with voltage applied to a circuit. It will not work and will probably ruin your meter.
If you didn't misunderstand what he was wanting to do, then I would say you need a new mechanic.
blck90vette
sorry badduck...i failed to mention that my car,will not start,,,CRANKS..but will not start,,,it all started when he changed out 3 injectors,,ran well for 2 days,,then it died,,towed it back to him ,he say`s there is no pulse to the injectors (noid light),changed ecm`s,Notta,,fuel pressure good,,fuel filter and pump,,good,,,,i`m leaning toward the other injectors,,,and i`m asking for a resitance test for the injectors,,,and that`s what brings me to my original post,,,,i`m not a mechanic,,but people are asking me " what`s the resistance of each injector when cold",,,that`s why i asked can it be done with out car running?,,,,thanks
Old May 20, 2008 | 10:33 PM
blck90vette
he`s saying he can`t take readings because of no power/or ground to injectors,,because car wont start,,thats why i`m asking is he right?
Old May 20, 2008 | 10:53 PM
Yellow2015's Avatar
Yellow2015
You not only don't need power to take an ohm reading, it's recommended to remove the power SOURCE when doing it. Tell him to read Ohm's law.
Old May 20, 2008 | 11:48 PM
65Z01's Avatar
65Z01
Either there's missed communication between you two or he does NOT know how to do a resistance measurement.
You must UNPLUG the harness from the injector in order to make the resistance measurement across the contact pins of the injector...
So there is no pulse to either left or right bank?? A '90 L98 is bank fired that is each bank is fired at once by it's own driver inside the ECM. If the ECM is firing neither bank either the ECM is defective or connected wrong. He should connect a scan tool to the ALDL connector, turn On the ignition and see if the ECM is communicating normally.
Old May 21, 2008 | 12:05 AM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
has anyone checked the injector fuses?
Old May 21, 2008 | 12:33 AM
396chevy's Avatar
396chevy
in my opinion at this point it dosent really matter what the resistance of the injectors is if they arent being pulsed i believe that the injectors are constatly supplied power and the computer cycles the ground to make them pulse. if you have power but no ground the drivers are probably bad if you dont have power at least we narrowed it to the power side of the circuit.
Old May 21, 2008 | 07:39 AM
BADDUCK's Avatar
BADDUCK
YES!
Old May 21, 2008 | 08:50 AM
jfb's Avatar
jfb
Check both injector fuses first, with an ohmeter! To measure resistance on an injector, the injector must be unplugged in order to gain access to both of its terminals, so it really doesn't matter if the ign is on or not, but it doesn't make any sense to unplug an injector and measure the resistance of the injector coil with the ignition on! If the mechanic thinks the ign has to be on, then he isn't familiar with fuel injection and you need to look for a more informed mechanic! See if you also have spark while cranking because the ECM uses the distributor pulses to time both the spark timing and the injector timing.
There is value in measuring the d.c. resistance (what an ohmeter measures) because a very low resistance can burn out the injector fuse/s, but for injector operation, d.c. resistance is a very poor measurement. A turn to adjacent turn short in the injector coil cannot be seen with an ohmeter and it can ruin the injector operation, but if you have an impedance bridge, you can easily find a turn to turn short.
Old May 21, 2008 | 10:27 PM
RACER 1993's Avatar
RACER 1993
Instead of spending the money paying this mechanic, may I suggest you spend about $60 and buy a Digital volt meter. You can learn to check some of this stuff yourself. There are posts on this forum about darn near anything and mechanics are pretty expensive these days.
You can always take the car back to him if you can't figure it out.
Old May 21, 2008 | 10:45 PM
Dads90's Avatar
Dads90
OK I've stayed quite long enough, stiff the mechanic, it sounds like he'll do you more harm than good ($$$$). I agree with allot of folks. You should take the money you would spent on a mechanic and invest it in the tool it takes to get the job done. AKA ohm meter. With forum help and your willingness to learn you'll feel better about a corvette accomplishment. Once you diagnose this problem you can approach a mechanic and he'll won't be so likely to take advantage of you if you can communicate with him.
To injector resistance readings
