Pulley installation help
Old May 21, 2008 | 04:09 PM
pt's Avatar
pt
Default Pulley installation help
Hi, Im about to installed my pulley and I noticed that it has an arrow on it. Which way should the arrow be pointing? Thank you.
Old May 21, 2008 | 04:13 PM
wro87's Avatar
wro87
Which pulley? Do you mean the balancer? wro87
Old May 21, 2008 | 04:22 PM
pt's Avatar
pt
Default pulley
Yes that round thing right in front of the optispark.
Old May 21, 2008 | 05:55 PM
MarkBychowski's Avatar
MarkBychowski
I just checked my service manual to be safe
With cylinder #1 at TDC, the arrow should be pointing to 12:00 (straight up).
The trick is knowing when #1 is at TDC since there's no easy way to tell unless you have something you can stick in the #1 plug hole to know when the piston is exactly at the top.
Old May 22, 2008 | 12:33 PM
geist's Avatar
geist
If you didn't take the hub off too, look for a mark on the hub. My 92's hub has a well defined ridge.
I just got a puller and plan to take my hub off Real Soon Now, and from what I read here the hub spline is not keyed for remounting in the correct position.
To Pulley installation help
