longer wheel studs
Old May 21, 2008 | 07:46 PM
pr0zac's Avatar
pr0zac
Default longer wheel studs
the track that i go to the tech is getting really **** and i want to run slicks here pretty soon.. i was wondering if anyone had a part number for longer than stock length wheel studs for our cars so i can pass tech without issue??
Old May 21, 2008 | 08:20 PM
WVZR-1's Avatar
WVZR-1
You want these GM wheel studs: 22551491 They're 12mm X 68mm long and work well.
Old May 21, 2008 | 08:23 PM
pr0zac's Avatar
pr0zac
they will work with my stock lug nuts?
Old May 21, 2008 | 08:24 PM
CFI-EFI's Avatar
CFI-EFI
If you mount the slicks on stock configuration wheels, the stock studs and lugs should be legal. If you are using a wheel with a thicker web, the stud must be long enough to extend into the hex portion of the nut, a distance equal to the diameter of the stud. The cheap, easy, way is to mock up a wheel to determine how long a stud you need. Then knock out a stock stud and head for the Dorman department at the local auto parts store. Stock style studs are available in longer lengths. The real right way is to order special racing studs from someone like Strange Engineering. More work and more money, but worth it, if you have the power to need them. If you use open ended lug nuts you will fly through tech in a breeze.
RACE ON!!!
Old May 21, 2008 | 09:26 PM
_twisted_'s Avatar
_twisted_
no they wont you need open ended lugs , summit has them -unles you leave the caps off
Old May 22, 2008 | 05:44 AM
pr0zac's Avatar
pr0zac
i have open ended lug nuts..
Old May 22, 2008 | 12:14 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I use these and they work with factory lug nuts.
You can see them pretty good in this photo.
Old May 23, 2008 | 10:30 PM
rodj's Avatar
rodj
I have ARP 100-7708 studs
look to be similar pricing to the GM ones.
http://store.summitracing.com/partde...5&autoview=sku
To longer wheel studs
