CFI vs. TPI Buildup
There are benefits to manually advancing the distributor to a larger bias than stock on an electronic distributor, such as to decrease the distance between the rotor an the terminal for applications where the total advance might achieve the limitation of 45 degrees BTDC.
-- Joe
How else do you change the timing? That IS the way to set the timing. What is funny is your emphasis on, indicated by capital letters, "an ELECTRONIC FUEL INJECTION SYSTEM". Twisting the distributor in "an ELECTRONIC FUEL INJECTION SYSTEM" has exactly the same consequences as doing so with a carbureted engine. Besides indiscriminately cranking in the advance, subscribes to your simplistic theory of:
With the first generation electronic distributors, the advance was built into the module and could not be altered. I'm guessing this is what started the ignorant trend of globally moving the distributor.
With newer systems (late 70s, early 80s CC carb) the advance is done in the chip based on engine load, RPM.
In reference to removing the ECM in a carb conversion, comes THIS gem:
When confronted with wild rantings, it pays to apply a little common sense to weigh the merits of the claims. It doesn't hurt to consider the source, either.
-- Joe
-- Joe
Just because you "fail to see" something that is clearly evident to many, is no excuse to poison the minds of the young and impressionable people that simply want to learn about their cars. Statements like "The more spark you can run, the more power you can make. It's pretty simple really.", and "I wouldn't have removed the computer, it can still control the timing. serve no purpose in a place where people are seeking serious help and advice on their projects.
RACE ON!!!
The point was: Moving the distributor GLOBALLY changes it. If you are moding a computer controlled ignition, you should be making changes in the bin. There are a lot of other tables that effect timing as well.
I'm pretty comfortable where I am, thank you.
Thats not me. thats him.
This is coming from a guy who doesn't modify advance tables but just turns the distributor.. wow.
The advance table is based on load vs rpm. Obviously a MAP (or maf) signal would be required, much as it existed (MAP) on the older CC carb applications.
In regards to the other thread with the carb swap, he was doing it on a '90+ car which does not have a VSS buffer in the dash. His 4000PPM VSS is wired directly into the ECM. My statement about keeping the ECM was because unlike you, I know what I'm talking about.
The fact remains YOU do not understand what I'm talking about so you choose to try and discredit me with your typical nonsense. If you can't tune an ECM fine. If you don't understand how the code works well that is fine too.
The second statement. You just simply have no clue what you are talking about. Perhaps a few of the other guys with '90+ cars can chime in and explain to your simple mind why they left the ECM in place to keep the CCM and speedo/odo happy. Not to mention it will have absolutely ZERO idea that the injectors, IAC, and TPS are not there anymore and the advance tables will work as they always had.
I don't know why you feel so threatened by me.
-- Joe
