Rough Running '85
Old May 24, 2008 | 05:09 PM
Demonic85's Avatar
Demonic85
Originally Posted by Roger420
My mustang was doing the same thing. Replaced the MAF and good as new.
sounds EXACTLY like a MAF problem. I did the same thing you did, fought with the electronics trying to figure it out. Exact same symptoms you have and it was the MAF. If you get funny voltage signals then its possible that it could be the MAF module.
Old May 24, 2008 | 08:16 PM
schrade's Avatar
schrade
Originally Posted by williammackean
With the other MAF, it was instantaneous. Fan comes on and the idle started dipping & fluctuating until it stalled.
That has gotta' mean that the fan amp draw is hittin' the current for the MAF.
Not gettin' it's share of current when the fan powers up? Are they both on a common source? Or a common ground?
Can ya' wire in a temporary ground wire for the MAF?
If it does misbehave with the fan disconnected, what should I look at to fix?
If it does start cuttin' out, with the fan disconnected (because it has reached 'x' temperature), ... ?
??? I can think of nothin' that's gonna' happen that would change tune. Maybe a code might trip for a fan fault, but nothin' for tune function.
What if it doesn't? Is it probable that wires are getting leakage onto each other? Where would this be?
Old May 24, 2008 | 08:27 PM
schrade's Avatar
schrade
Try this, just to see what ya' get...
COLD motor, by-pass the coolant temp sensor to fire the fan when you turn on the motor.
Observe results.............................
Haynes don't say if the MAF and the fan power are on the same circuit.
