Bushing grease
Old May 24, 2008 | 08:40 PM
Tom 35th anniversary's Avatar
Default Bushing grease
I did a quick search to no avail. I am installing poly bushings in my rearend while I have it out. Exactly how much grease, and what surfaces should get it. I assume the surface that touches the aluminum pieces, and the hole through the centers. Just want to make sure before I start.
Old May 24, 2008 | 08:48 PM
schrade's Avatar
schrade
Lithium grease?
Thin film usually is good enough...........
I've heard silicone oil too, but more often for rubber bushing that poly bushings.
Old May 24, 2008 | 09:18 PM
Originally Posted by schrade
Lithium grease?
I'm going to use the grease/lube they sent with the bushing kit, just wanted to know exactly where to lube.
Old May 24, 2008 | 09:51 PM
mseven's Avatar
mseven
I always thought the grease supplied is used for instalation (outer area and metal bushing) purposes. This would allow it to be pressed in easier. From there I took a little m1 syn grease and appiled it to the wear surfaces.
Old May 24, 2008 | 10:07 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You have the right idea, just apply a liberal amount to wherever the bushing will touch metal...
Old May 24, 2008 | 10:10 PM
Cool, will do tommorrow.
To Bushing grease
